20 Most Recent Soundstorm Force F2800 Car Audio Amplifier Questions & Answers
Gos in to protection mode
Check for a short circuit in the wiring of the output speakers or a shorted speaker voice coil, also check for correct voltage to the POWER AMP while in use... when an AMP goes in protective mode this means two things A SHORTED OUTPUT or A INCORRECT VOLTAGE TO THE POWER AMP. if all the above is OK than the AMP is defective. are you using correct speakers OHMAGE 4, 6 8ohms??? according to your AMP.
2/25/2013 3:06:33 PM • Soundstorm Force... • Answered on Feb 25, 2013
I have the sound storm f2800 and the red protection light is on
it i possible to fix your amp...the thing is its gonna your speakers if you place sumthing wrong...
10/6/2009 7:26:56 PM • Soundstorm Force... • Answered on Oct 06, 2009
FUC% the protection light
i had a similar problem with my amp (although a different brand). Check you ground connection and make sure it's not grounded to metal with paint covering it. This is NOT a solid ground connection. You must remove the paint then reconnect it. Without a solid connection to ground, it cant run for very long without going into protection mode. Hope this helps
7/27/2009 6:30:51 PM • Soundstorm Force... • Answered on Jul 27, 2009
Protection light
The most common cause for this is shorted output transistors.
3/13/2009 2:04:53 PM • Soundstorm Force... • Answered on Mar 13, 2009
Soundstorm amp
Your D-SERIES amplifier was designed to operate efficiently at loads down to 2 Ohms.
This means that you can install four 8 Ohm speakers per channel when using parallel wiring.
of an additional 10W to each speaker.
Please note: The gain control of any car audio amplifier should not be mistaken for a volume
control. It is a sophisticated device, designed to match the output level of your audio source unit to
the input level of the amplifier . Do not adjust this input level to maximum unless your input level
requires it. Ignoring these instructions will result in an input overload to the amplifier, and excessive
2 Ohm Operation
front panel will be illuminated, indicating the amplifier has gone into a self-preservation mode.
these conditions before attempting to power up the amplifier again.
When operating at 2 Ohms, the amplifiers will increase their output power by approximately 50%. The
current draw will so increase by about the same amount, also be sure you have enough current to
run the amplifiers into a 2 Ohm load. If you lack adequate current, your music reproduction will be
distorted.
Increasing the number of woofers per channel at low frequencies (up to 100MHz) produces an acoustic
coupling effect. This acoustic coupling increases your power output by 3 dB per speaker, or the equivalent
audio distortion. It can also cause the protection circuit to engage.
1/7/2009 2:03:18 PM • Soundstorm Force... • Answered on Jan 07, 2009
Sound Storm F-2800 Amp
you can you own sound but you have to eliminate the rare channels and use them for your self to conect the Subs and other stuff. Take care for the Power rating and just let the music play!!! Patrick
8/29/2007 7:04:33 AM • Soundstorm Force... • Answered on Aug 29, 2007
I HAVE A SOUNDSTORM SD960TS AND I DONT HAVE THE
My screen won't come out and when I get it out it's not on I did lose the face but every thing else works what do I do
5/23/2012 4:57:39 AM • Soundstorm Car... • Answered on May 23, 2012
0answers
Can a soundstorm F2500D handle a subwoofer
Hello sincere4140,
The Soundstorm is stable only to 2ohms.
Hope this helps.
7/29/2009 3:48:19 AM • Soundstorm Car... • Answered on Jul 29, 2009
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
12/5/2008 12:40:48 AM • Soundstorm Car... • Answered on Dec 05, 2008
I bought this pionner dvd model no.avic f 9880 dab but it was password how do i reset or remove it from being password protected
I would contact Pioneer. After proving ownership, they should be able to help. https://www.pioneer-car.eu/eur/support/contactform
5/21/2024 7:05:35 AM • Car Audio &... • Answered Yesterday
How can I free down Elipse AVN1106D CD driver software?
it is not a computer but is CAR sound systems. the answer is ask the maker for support. read post 10 https://www.pakwheels.com/forums/t/eclipse-avn1106d-map-disc-required/226389
5/17/2024 12:20:07 PM • Car Audio &... • Answered on May 17, 2024
2004 Lincoln Navigator (Canada) 6-cd changer stereo died. I want to get an after-market stereo but not sure what else I need? Which wire harness I need, connector, adaptor or installation kit?
Like for like. Go to a breakers yard. The audio system is an extension of the Body Control Module, part of the computer system and is used to Audio Alerts, Chimes etc. that play through the speakers. If you replace it with a completely different unit, the BCM won't understand the data. A company like Crutchfield will guide on you what _might_ work, and they will also supply harness connectors. It needs to be specific. https://www.google.com/search?q=2004+Lincoln+Navigator+(Canada)+6-cd+changer+stereo ..
5/12/2024 12:31:47 AM • Car Audio &... • Answered on May 12, 2024
How to set time and alarm in KADIO KD-3810N
Insert Batteries: First, insert 2 AA batteries into the back of the clock. Access Time Setting Mode: Press and hold the Mode button for 5-10 seconds until the clock enters the setting mode. Adjust Time: Once in the setting mode, use the Up and Down buttons to change the time, month, and date. Press the Mode button to cycle through the different settings. Set Hour and Minute: When you reach the time setting, adjust the hour and minute using the Up and Down buttons. Press the Mode button again to move to the next setting (e.g., month, date). Exit Setting Mode: After setting the time, press the Mode button to exit the setting mode.
5/10/2024 4:28:29 PM • Car Audio &... • Answered on May 10, 2024
I have been trying to get my X DVD 276BT to Re game sound back at 1st I didn't hook up My Pink break I did however hook up the illuminations Orange wire to the Orange and white to harness Had issues when using my dimmer I cut dimmer all the way up my radio would stop flashing other settings on my dimmer switch would make my radio Flash I liminate did my Orange wire and grounded my Pink brake wire to the back of radio I'm getting a blue screen no signal Does anybody have an idea how to get my sound back I did have sound it started losing sound when I would Bluetooth for some time it would cut out I would turn the radio off then back on and it would start working again now I can't get the sound to work at all is there anybody that can help me with this issue it were be greatly appreciated riding in silence is very depressing lol
Whew I'm not sure the following will get you there. But it may give you more insight as to what is going on and that may give you more of an idea how to proceed. Troubleshoot the issue step by step: Check Wiring Connections: Make sure all the wires are properly connected according to the stereo's manual. Double-check the connections for the Pink brake wire and the Orange illumination wire. The Pink brake wire is typically used to prevent video playback while the vehicle is in motion. If it's not connected correctly, it might affect other functions. The Orange illumination wire is usually connected to the vehicle's dimmer switch. If there are issues with the dimmer, it could impact the stereo's display. Dimmer Settings: Since you mentioned issues with the dimmer, ensure that the dimmer switch is set correctly. Adjust it to see if it affects the stereo's behavior. If adjusting the dimmer causes the radio to flash or behave unexpectedly, there may be a wiring issue or a faulty dimmer switch. Grounding: You mentioned grounding the Pink brake wire to the back of the radio. Make sure it's securely grounded. Also, check if there's any interference or loose connections near the ground point. Blue Screen (No Signal): A blue screen typically indicates that the stereo is not receiving a video signal. Here are some things to consider: Verify that the video source (e.g., DVD player, external device) is connected properly to the stereo. Check if the input source is set correctly on the stereo (e.g., DVD mode). Inspect the video cables for any damage or loose connections. Test the stereo with a different video source to see if the issue persists. Factory Reset: Some car stereos have a factory reset option. Refer to the user manual to perform a reset and see if it resolves the issue. Consult the Manual: If none of the above steps work, consult the X DVD 276BT manual for specific troubleshooting steps or contact their customer support.
5/5/2024 5:04:45 PM • Car Audio &... • Answered on May 05, 2024
Soundstorm Force F2800 Car Audio Amplifier Logo
Popular Tags
10 questions posted
Top Soundstorm Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soundstorm Car Audio & Video
Most Popular Question
protection light
  • Car Audio & Video
