20 Most Recent Frigidaire 16.7 cu. ft. Upright Freezer GLFU1767F Questions & Answers
Hi Kimi, I am happy to assist you.
There could be various reasons why your freezer is freezing. There could be a faulty defrost thermostat or the vent from the freezer has been blocked and is forcing air back into the unit.
If we may suggest checking to make sure that items in the freezer are clear from the vents or walls in the freezer. If this is not an issue, it may be more of a technical issue and an authorized service provider would be able to better diagnose the issue.
If you do not know a professional technician, manufacturer websites often have service provider locators' onsite to assist you in that regard. If you have any additional questions, please feel free to reconnect!
Frigidaire 16.7... | Answered on Sep 12, 2013
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Frigidaire 16.7... | Answered on Apr 21, 2010
in settings alarm might be turned off
Frigidaire... | Answered on Feb 28, 2021
Disconnect the power again for 5 minutes and then put a dinner knife across the two mains plug pins. Then plug it back in. If it doesn't work after that you need an engineer. The main board or other components may have been damaged by a power spike when the power cut.
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
Frigidaire... | Answered on Jan 03, 2021
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Freezers expel warm air. There should be no 'blowing' inside. If it is expelling warm air, then it is working fine, eventually the expelled air should get cooler and cooler.
Frigidaire... | Answered on Jun 06, 2019
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered on May 20, 2019
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
Frigidaire 16.7 cu. ft. Upright Freezer GLFU1767F Logo
2 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
ce flashing in temp window upright
  • Freezers
