20 Most Recent LG LMVM2055 Convection/Microwave Oven Questions & Answers
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
LG LMVM2055... • Answered on Jun 22, 2016
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
LG LMVM2055... • Answered on Nov 30, 2013
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
LG LMVM2055... • Answered on Sep 06, 2011
heatman101
Hi, Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
LG LMVM2055... • Answered on Aug 30, 2011
Please post a new help request with brand and full model.
LG LMVM2055... • Answered on Jul 13, 2011
Yes you can use a hair dryer but the power should be off so that you don't short it out any more than it already is. Most likely the keypad has been ruined and will need replaced., Once these go bad there is no fix except to replace the keypad.
LG LMVM2055... • Answered on May 08, 2011
Hi and welcome to Fixya, I am Kelly. This is usually from the Child lock being activated: 1. Touch STOP/CLEAR.
2. Touch and hold START/ENTER more than 4 seconds.
LOCKED will disappear and two beeps will sound.
Thanks for choosing FixYa, Kelly
LG LMVM2055... • Answered on Mar 26, 2011
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
LG LMVM2055... • Answered on Mar 10, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
LG LMVM2055... • Answered on Feb 22, 2011
Sounds like a replacement control panel will be required. They do fail and usually are not a serviceable part.
Call an engineer for fitting.
LG LMVM2055... • Answered on Jan 19, 2011
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
LG LMVM2055... • Answered on Jan 09, 2011
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
LG LMVM2055... • Answered on Jan 03, 2011
Remove the keypad and use a multimeter to test it for continuity. If the keypad is not getting power then it has shorted out because of the excess condensation. Replace the keypad, it will cost around $30 for the part. Click on the link link below to order the part you will need:
http://www.repairclinic.com/PartDetail/Touchpad/1304975
LG LMVM2055... • Answered on Oct 24, 2010
You likely have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
LG LMVM2055... • Answered on May 31, 2010
auto defrost can require a weight to be input for it to calculate time. glass such as Pyrex can be used
LG LMVM2055... • Answered on Feb 17, 2010
Can't help with part number as it's not an Australian Model, but refer to http://us.lgservice.com/index_b2c.jsp to help you find a service location!
LG LMVM2055... • Answered on Mar 19, 2009
LG LMVM2055 Convection/Microwave Oven Logo
31 questions posted
Top LG Microwave Ovens Experts
Dan Webster
Dan Webster
Sheldon Dedek
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
only few buttons
  • Microwave Ovens
