20 Most Recent NetGear JFS524 24-Port Ethernet Switch (0606449023831) Questions & Answers
Switches don't have DHCP server built in.
NetGear JFS524... | Answered on Oct 19, 2014
Hi Ewan,
How is the modem/router connected to the switch?
Have you tried changing the patch cable that connects them together, or the port they are connected from?
When troubleshooting this type of issue, it is always best to check each layer of connectivity (1-Physical,2-Data Link, 3-Network Addressing, etc.) in order from bottom to top, due to each layer being dependent on the layers before it.
DNS is important but wont be available until you have a physical connection and a IP address.
If you can achieve a stable connection while the PC is connected directly to the modem/router, but not via the switch then work your way from one end of the link between the working component (in this case the modem/router) to the other (PC) - testing each part along the link.
If the switch is faulty after you have performed some testing, it is best to change it out and test with another switch (if avalible), before purchasing or sending the JFS524 away for repair (if still under warranty).
Let us know how you go with the testing.
NetGear JFS524... | Answered on Aug 15, 2009
https://www.google.com/search?sxsrf=ALeKk03PaBlhbIut8HXkWqf7V-HpEgzhdg%3A1585151795759&source=hp&ei=M397XuehLInDlwSL3664Aw&q=Netgear+extender+setup&oq=Netgear+extender+setup&gs_l=psy-ab.3..0l10.2265.2265..3448...2.0..0.245.245.2-1......0....2j1..gws-wiz.....10..35i362i39.kIdrteiVKc0&ved=0ahUKEwinh8zN_rXoAhWJ4YUKHYuvCzcQ4dUDCAU&uact=5#kpvalbx=_1oF7XuuSHITyasH6vLAI26
NetGear... | Answered 2 days ago
The important thing is the voltage and to equal or exceed the current.
Your drive required 2 Amps so a 2.5 Amp power supply will be fine.
What about the 5 Volt logic supply ... is that used on your drive I wonder. Some do, some don't.
CONTACT THE ROUTER SERVICE PROVIDER MY NETGEAR HAD IT ON THE BOTTOM OF ROUTER
NetGear... | Answered on Mar 16, 2020
READ THE DIRECTIONS THEY PROVIDED YOU
Install the correct win 10 drivers from netgear.
NetGear... | Answered on Feb 05, 2020
Go to the Netgear website and check for the support link, go to that link and look for firmware updates for your model. They install from the computer side of the LAN, you may need to run CAT 5 cable to the inputs to do it.
NetGear... | Answered on Dec 20, 2019
DO YOU HATE ALL THE SPAMMERS AND SPAMMING HERE ON FIXYA ??? USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!! ALL TOLL FREE TOO!!
THIS IS A COLLECTIVE PHONE LISTING OF ALL THE SPAMMERS HERE ON FIXYA. WE SUGGEST YOU DONT CALL ANY OF THEM UNLESS YOU KNOW WHAT YOU ARE DOING !!
1-85O-8I2-4OO9 1-8OO-8O3-1O69 1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 l-855-892-OO6O 1-888-570-9791 1-855-26O-OO64 1-855-536-5666 1-844-24O-9111 1-8OO-55O-5195 1-845-481-1722 1-855-616-7697 1-844-819-3382 1-855-221-4867 1-845-481-1722 1-800-258-1449 1-845-764-4808
IF YOU KNOW WHAT YOU ARE DOING HAVE SOME FUN WITH THESE LOSERS AND LETS BEAT THEM AT THEIR OWN GAME.. CARRY ON10
NetGear... | Answered on Dec 03, 2019
Manuals are available on the Netgear website, search for your particular model
https://kb.netgear.com/23517/How-do-I-set-up-my-NETGEAR-WiFi-Range-Extender
NetGear... | Answered on Nov 13, 2019
netgear vmv 3000 base
did you not mean VMB3000? google sees no VMV so....
what are you attempting to connect to what>>
a camera is that what it is?
maybe as on their web site, the designed to so...
https://community.arlo.com/t5/Arlo/how-to-setup-of-vmb3000/td-p/1212018
NetGear... | Answered on Sep 14, 2019
Hi , I was also facing same problems.I have solutions please follow some steps:
1.Restart Your Main Wireless Router And Modem.
2.Now Turn Off Your Belkin Range Extender And Wait For 20 seconds (unplug From Power)
3.Please Plug Your Extender Back To Power Outlet And Restart Your Computer.
Still Having Problems?
Don't Worry Visit here for more solutions:
Belkin Range Extender Won Connect to Wireless Router TechVaidya
NetGear... | Answered on Aug 30, 2019
To perform a factory reset:
  1. Verify that your router's Power light is on.
  2. On the back of your router, locate the Restore Factory Settings or Reset button.
  3. Use a paper clip or similar object to press and hold the Restore Factory Settings or Reset button for seven seconds.
  4. Release the Restore Factory Settings or Reset button.
    Your router resets.
When you log in to your router again, use the default login credentials:
  • User Name: admin
  • Password: password
NetGear... | Answered on Aug 18, 2019
NetGear JFS524 24-Port Ethernet Switch (0606449023831) Logo
7 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
netgear jfs524 24 port switch build in
  • Computers & Internet
