20 Most Recent Rockford Fosgate p-450.4 Car Audio Amplifier Questions & Answers
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Rockford Fosgate... • Answered on Dec 18, 2014
Check your ground. At the battery check for oxidation, check your RCA's and make sure they are tight. It's usually something that's loose or rusted/corroded. If you still have noise, post a comment with car make model and year as well as audio products installed and I can help you troubleshoot further. Hope this helps.
Rockford Fosgate... • Answered on Aug 17, 2009
Hi try http://www.alliedelec.com , they are based in the states and will ship. Not sure if what you are looking for is generic or specific, but they have a pretty good range.
Good luck
Rockford Fosgate... • Answered on Jul 11, 2009
Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
Rockford Fosgate... • Answered on Dec 22, 2007
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Rockford Fosgate... • Answered on Nov 22, 2007
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
Rockford Fosgate... • Answered on Sep 24, 2019
You may not have enough ground connection or your are running too much power for your amp
Rockford Fosgate... • Answered on Jun 12, 2019
Yes. Wire the two 2 Ohm speakers in series and connect them to one channel. Connect the 4 Ohm speaker into the other channel. This will give you a balanced 4 Ohm load on each channel.
Rockford Fosgate... • Answered on May 12, 2019
i have a punch 45 but i'm missing the speaker wire connector.... were do i go to get one...
Rockford Fosgate... • Answered on Feb 03, 2019
Rockford Fosgate p-450.4 Car Audio Amplifier Logo
12 questions posted
Top Rockford Fosgate Car Audio & Video Experts
Daniel Dollive
Daniel Dollive
Steve Sweetleaf
Steve Sweetleaf
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Car Audio & Video
Most Popular Question
amp blowing fuses
  • Car Audio & Video
