20 Most Recent
D-Link DWA-643 Wireless Adapter Questions & Answers
DWA-643 installed but unable to access any wireless point
check the status of the device under Device Manager first and see if it was properly installed. If yes, you may use the wireless zero configuration utility built-in to XP or Vista. If your OS is lower than XP you have the use the utility provided by D-link. It usually comes with a CD installer for its driver and utility.
Please rate and see if it helps. Thanks and goodluck.
What is the appropriate driver?
Go to dlink.com and search for drivers for your particular device. They are free to download. If you included the model I would have provided a link.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
