I am trying to open up a Shure PG58 wireless microphone in order to repair its on/off switch. Can anyone help, please?Type your problem for a solution...
No, do NOT pry things off or damage the casing like these guys said, first, unscrew the the collar right under the mic head, the head will come off with the collar, then uscrew your battery access cartridge, remove the battery, look on the opposite side of where your on/off switch is there is a small black philips head screw, remove this screw, then push on the positive and negative contacts that your battery plugs in to and this will slide out of the hand held cartridge, and that is your circuit board, the on/off button is on that circuit board. get you some contact cleaner spray and spray a little on that button, let it dry for a few minutes and then plug your battery into the end of that circuit board and push that button in and out quiet a few times and it should start working properly for you, did for me.
1/31/2014 9:05:30 PM •
Shure...
Answered
on Jan 31, 2014
