20 Most Recent
Bose Companion II Computer Speakers Questions & Answers
How do I get rid
Follows general advice for all speakers exhibiting a Hummmming.
Use shielded cables if you aren't already. If you can, ground the shield to the chassis of the device supplying the signal to the speakers. Keep the speaker wires as short as possible. If you can, reverse the plug of the source. If you have multiple devices, try to plug them all into a power strip (tape deck, phono, amp, tuner, etc)
I hope this helps ...
Thanks for your question @ FixYa.com
My problem is that i don't know how to turn off my
No power switch on this model. It goes into standby mode to conserve power. If you want you can buy a power strip or usb power strip (so you can turn it off via your pc) and then power that off with the speakers plugged in.
Hope this helps
My left speaker has a flutter sound. In and out.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Get loud hum from both
connection is good
computer
try cleaning
hope this helps
Occasionally i cant get any sound to come out of
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Just got new Companion 2
Fascinating, make sure you have the absolute latest edition of I Tunes (I've had experience with people not being able to play their library without having the newest version.) If you have a good internet connection then you may want to simply un-install Itunes and do a completely new download and install. Make sure the volume slider on I Tunes is not all the way down. Also if these don't work try going to your "Sound" applet in control panel;
-under the playback tab click the properties button (be sure your speakers are selected)
-move over to the advanced tab
-be sure both boxes are checked under exclusive mode:
(allow application to take exclusive control of this device) and (give exclusive mode applications priority)
I hope some of this helpful. Thanks.
Plugged Bose speakers into HP
The problem has to be at the sliders (the faders) at the volume mixer for your audio device. Open the mixer (double click on the speaker icon at your taskbar) and get all the way up the sliders for WAVE and MASTE. Of course check for not any of them being muted. In some cases the jack on the laptop makes glitches so plugin and out several times a jack in order to avoid any case like this.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
New Computer No Sound
check where you plugged your jack on your pc. usually it is green in color.
check the volume control on your task bar. it might be just too low or mute.
some old speakers, require batteries.
check your speakers if is plugged on power outlet.
Bose Companion 2 speaker has crackly volume
The problem with the crackly sound is caused by dust or dirt in the Reostat that controls the volume. it needs to be cleaned, there are a couple of different types of Cleaners that you can use. Just be sure its safe for the application. (of course the cleaner part is common sense)
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
I would like to place my bose comanion II speakers
My guess is you have coax speaker cable -- if so, you can use standard audio cables with RCA plugs -- Radio Shack would have them -- match plugs so you can chain the cablestogether.
If you have twin-axial speaker cable, best approach is to just buy speaker wire of the correct length... or if there are plugs on the current speaker wires, you can splice in enough new speaker wire to reach the new location for the speakers.
Charlie
Coax looks like a single cable, but has one conduction inside the other.
Twin-axial has two obvious conductors, side-by-side.
