20 Most Recent
Denon AVR-987 Receiver Questions & Answers
My Denon Receiver AVR-987 keeps turning itself
That is a common problem for many receivers. Over heating, amplifier overload etc. Are you playing material through it at a very loud volume for an extended period, particularly with a lot of bass? If so try turning it down and/or defeating any equalization or turning the bass control back to zero. If you moved the unit make sure it is getting enough air flow and that there is no other heat sources near it or anything sitting on top of it.
I have a Denon-987 receiver. I setup the speaker
There's no user parameter for "no sound during Test Tones" so a reset would be futile.
Carefully examine the front panel for clues like a misplaced Mute, Tape control or Multichannel Analog (EXT) Input selected.
I have denon avr 987
Are your DD TV and DBS referring to the same source device or are they separate, say, cable Box and Sat Box?
Start over with the digital audio assignments for wherever you plugged in the digital audio cable from (guessing) your Cable TV box (recommended as "TV" is not usually a great source for audio).
The manual:
http://www.retrevo.com/support/Denon-AVR-987-Receivers-manual/id/696dj079/t/2/
You might also want to define the specific cabling of things if more is required. Exact point-to-point paths and cable styles for audio and video.
Whenever I start playing on
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Our denon receiver keeps going off-
replace all the electrolytic capacitors in the power supply. i had the
exact same problem with mine and once i replaced the capacitors it
powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Im trying to hook up my wii to my surround sound
Connect all of your cables to your display and then connect another set of cables to your audio variable out from the television to the input you wish to get sound from on the receiver. Then make sure your tv is selected to the input you plugged the wii into, for example, Front video or Video 1 etc etc.
Durabrand 2.0 CH USB Speaker System
Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction.
Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do.
This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective.
Hope this be of help/idea. Post back how things turn up or should you need further information.
Good luck and kind regards.
Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Minimal sound out of all of my speakers
it could be there is not a driver installed on your computer in which case you have to download a driver and Best Buy can tell you how to do that. Also check in control box and make sure volume is not set to mute
Fuzzz on speakers, no computer sounds
you may not have a driver installed on your computer you will need to download a driver if so also make sure computer volume seetings are not set on mute
Component Video input not working for Video game consoles
Well, as far as I can tell, the WII does work, BUT...is it possible that your choice of INPUTS on the Denon unit may only process 720 or 1080 resolutions and not 480P which is the LIKELY output of Wii !
Can you swap your Xbox to the intended input on your Denon and see if you can set it up with that?
If so, that's your problem.
IF NOT, then dig into the Video Setup on the DENON a little deeper. We know for a fact the Wii does work correctly, we just need to know if Denon made ALL video Inputs capable of ALL Resolutions
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
