20 Most Recent Creative Labs Live! Cam Voice Webcam Questions & Answers
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu.
Creative Labs... | Answered on Feb 03, 2013
1st You download Webcam Driver.
Web cam driver
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Creative Labs... | Answered on Sep 18, 2012
dwon load software for my Creative Cam Model ,VFO260
para instalar la camara wed ceative
installed in the system
i got that camera but i loss software so where i acn get software for live cam voice
Creative Labs... | Answered on Jan 14, 2012
Copy this site and paste it into your web browser and hit ENTER.
After getting on the site, select your camera image and click on it.
http://support.creative.com/Products/Products.aspx?catid=218
Also try this site:
http://support.creative.com/kb/ShowArticle.aspx?url=http://ask.creative.com:80/SRVS/CGI-BIN/WEBCGI.exe/,/%3FSt=385,
E=0000000000381624595,K=6684,Sxi=13,Answer44111=obj(44111):obj(44143)
When you get to the next window, there is the download for your camera.
Then when that page appears, select your camera, and be sure you select ENGLISH and click on the DOWNLOAD on the left.
Next, before installing the software, DISCONNECT the camera from the USB port and install the CD Software program or the Downloaded program.
When the program asks you to connect the camera to the USB port, THEN DO SO.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up
to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Creative Labs... | Answered on Oct 09, 2010
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Click OK and it should work.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Creative Labs... | Answered on Sep 23, 2010
Plug in your camera.
From your Control Panel navigate to the Device Manager and look for any driver alerts ( warning triangles / question marks)
Expand the 'Imaging' folder and right click on your webcam text
Make sure the camera is enabled
You can try this diagnostic software but it does not highlight driver problems
http://www.download32.com/webcam-diagnostics-d35065.html
Creative Labs... | Answered on Sep 06, 2010
The driver is part of the software you installed your camera.
DO THIS:
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Creative Labs... | Answered on Aug 12, 2010
there are books written about photography but i will tell you a little,
shutter speed the faster the shutter speed the less light goes through this basically helps to take fast moving objects, now in darker situations you may decrease the shutter speed but you'll have to hold the camera steady and longer or tripod it,
the rest you can find on
http://www.dpchallenge.com/tutorial.php?TUTORIAL_ID=45
Creative Labs... | Answered on Jul 29, 2010
Try the Creative website support first
Creative Labs... | Answered on Jun 26, 2010
It seems that the device gets heated up and starts malfunctioning. The audio chip seems to be going away. Then, when it cools down due to disuse it starts working again. This is a sign of weakening of the chip. The mic may be fine but the audio chip is going and needs replacement.
Creative Labs... | Answered on May 27, 2010
Check your computer audio settings to make sure the webcam mic is set as 'default'
Plug in webcam
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer and configure to your chat program
Creative Labs... | Answered on Mar 24, 2010
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Creative Labs... | Answered on Mar 12, 2010
Creative Labs Live! Cam Voice Webcam Logo
Popular Tags
53 questions posted
Top Creative Labs Computers & Internet Experts
Geoff
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Creative Labs Computers & Internet
Most Popular Question
alot questions
  • Computers & Internet
