20 Most Recent Samsung HL-S5686W 56" HDTV Questions & Answers
I have a Samsung HL-S5687WX/XAA and the screen is
you either have incorrect placed or bad avi cable lastly could be a dmaged main board in the TV since other connections such as hdmi work fine focus on the avi device your connecting and test it o another tv with the current cables i bet it is not the TV
3/7/2018 12:46:41 AM • Samsung... • Answered on Mar 07, 2018
All 3 LED's are blinking on my 56 inch LCD Model
first try re-seating the lamp by pulling it out and sliding it back in. You would need to take off right side back cover. Sometimes this can clear the error and may fix the problem altogether. If no, try clean All the fans inside the Television to preserve the life of the lamp.
10/30/2017 12:21:28 PM • Samsung... • Answered on Oct 30, 2017
The 3 led lights in front blink
Sounds like the lamp is out.
4/2/2014 2:46:01 PM • Samsung... • Answered on Apr 02, 2014
0answers
My Samsung television HL-R4667W has
Fan #2 is the lamp fan. I thought you are referring to DMD fan (fan #1) that you had been replaced. Fan connector #1 has a cable connected to the board. They are seat in side-by-side(same size connector and color, yellow and red) by the connector of the Fan #2(lamp fan). Pull-out this connector and then re-insert and ensure that it is securely connected to the board. Try if the symptoms still there, if yes then replaced the Lamp Fan.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
6/16/2011 3:14:09 AM • Samsung... • Answered on Jun 16, 2011
I have a hl-s5686w samsung dlp tv, the problem is
ok well it seems to be an issue either with yoru DMD board or your Digital Video board, go to the menu and if those white spots are also showed on the menu, the issue is with your DMD board, but if they're not showing, the issue would be with your Digital Video board
3/20/2011 4:09:41 AM • Samsung... • Answered on Mar 20, 2011
How do you replace a bulb in samsung projection tv
There is a video of the procedure here: http://www.samsung.com/us/support/owners/product/HL-S5686W . Make sure to get the exact matching lamp code number and type. This is listed on the right side of the TV and on the lamp case.
Then turn off the TV and let it cool for at least 30 minutes. Make sure not to touch the glass with your bare hands (particularly with the new lamp). Remove the single screw from the lamp cover and then remove the lamp cover. Remove the lamp cover duct by holding the locker and pulling it towards you. Next remove the screw holding the lamp in the housing. Separate the lamp from the housing by holding the handle and pulling it towards you. Reverse the process with the new lamp. Make sure the lamp cover is seated properly and the screw tightened to get the TV to come on.
I hope this helps.
1/30/2011 11:46:28 PM • Samsung... • Answered on Jan 30, 2011
I'd like to brighten up the picture kinda dim
Turn up contrast to 95 and turn down brightness accordingly. If it is oddly dim, you may have a problem with the backlight.
1/28/2011 3:24:39 AM • Samsung... • Answered on Jan 28, 2011
After turning on the TV, picture and sound are
Hi miskokids.
I had a similar problem with my 42 in Philips LCD HDTV. I may have the solution to your problem.
Here was MY problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you to consider.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It will, at the very least, give you a general idea of the process. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps.
If you have any questions for me, please comment on this page. I will be happy to assist you to the best of my ability. Thanks for using Fixya.
Kaufman605
12/22/2010 7:40:39 AM • Samsung... • Answered on Dec 22, 2010
Hi , 2 weeks ago i noticed some dead pixels
White pixels are STUCK pixels, not dead. Read the warranty beacuse at a certain number of stuck/dead pixels, the tv is repaired for free by the seller if is in warranty period.
11/2/2010 3:26:36 PM • Samsung... • Answered on Nov 02, 2010
Hi, on the screen it got a lot of white dots
Ligght Engine needs to be replaced.
Samsung Parts.com 1-800-627-4368
10/28/2010 9:19:51 AM • Samsung... • Answered on Oct 28, 2010
We replaced the lamp about
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
9/7/2010 2:17:43 PM • Samsung... • Answered on Sep 07, 2010
My samsung dlp hl-s5686w turns for a minute video
I'm having the same problem. Tried several things from dusting the inside with an air blower, removing the bulb and putting it back in, making sure the side panel is installed correctly and none of this has kept it from shutting off. Samsung's site says the three lights flashing means replace the bulb but I'm not buying it. My picture looks perfect....jsut that the TV keeps turning off. It all seems like a heating problem but my fans are still working. I'm scratching my head thinking what to try before forking out $150 for a new bulb.
8/15/2010 4:55:56 AM • Samsung... • Answered on Aug 15, 2010
All the lights on the front of the tv are
Hi:
First try replacing the lamp if the lamp does not solve your problem then have the lamp ballast checked as this unit light the lamp. If both are good and still failes then replace the Main system control board.
6/14/2010 3:45:11 AM • Samsung... • Answered on Jun 14, 2010
No power
Check the color wheel, take out lamp and look at color wheel with flashlight see if moving, make sure you tape down or up lamp door switch. If color wheel turns or not? Have same tv my probelm was the color wheel. cost around $70 easy to install>>>>
6/2/2010 6:31:51 AM • Samsung... • Answered on Jun 02, 2010
Samsung HL-S5686W 56 in. HDTV SHUTS OF EVERY 1O-15
if you're getting the 3 indicator lights coming on, more than likely you'll need to replace your tv lamp. open the panel and have a look in there. lamp probably blown.
4/14/2010 2:19:59 PM • Samsung... • Answered on Apr 14, 2010
The tv keeps telling me check fan 2 and 2 lights
You will need to replace fan #2 you can get the replacement fan from www.tvrepairworld.com
1/6/2010 11:30:15 PM • Samsung... • Answered on Jan 06, 2010
Samsung HL-S5686W 56" HDTV Logo
32 questions posted
Ekse
 Francisco Mauricio...
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
  • Televison & Video
