20 Most Recent Mitsubishi WD-73732 73" Television Questions & Answers
Is this a DLP or LCD projector?
Mitsubishi... | Answered on Mar 17, 2018
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Mitsubishi... | Answered on May 15, 2014
try a new PHILLIPS blub and see if it helps. DO NOT use a neolux--they will NOT work right !!
Mitsubishi... | Answered on May 08, 2014
Try the soft reset with the remote: menu,1,2,3 and enter.
Mitsubishi... | Answered on Dec 23, 2012
First see if it does this with a DVD etc connected--rules some things in and out.
Most of these have two resets, the soft and the hard-----if it has the soft with the Mitsubishi remote: (set on) Menu, 1,2,3 enter.
I would not do the reset if no issue with a DVD etc.
Mitsubishi... | Answered on Nov 05, 2012
check to see if the lamp connectors inside the lamp compartment didnt get pushed back inside the set. If they are still there secure inside the lamp compartment then you will need a new ballast which you can get from www.tvrepairworld.com
Mitsubishi... | Answered on Feb 23, 2012
check the ic in the color circuit or the resistor that connects to the collector of the kine transistor.these components can be faulty.probably it is a module so you might need to replace the module that has on the color circuit check the transistor also.good luck.
Mitsubishi... | Answered on Sep 25, 2011
Just curious if you resolved this issue by replacing the lamp. I have the exact same problem.
Mitsubishi... | Answered on Sep 11, 2011
The DLP chip in the lt engine needs replaced.
Mitsubishi... | Answered on Sep 01, 2011
The way that you change the color on this TV is thru the audio/video menu, under Perfect Color. It show you how in your owners manual on page 74. If you no longer have the owners manual you can downloaded it here http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73732.pdf
Mitsubishi... | Answered on Mar 02, 2011
Unlike bulb, It is hard to find the ballast of your TV. I suggest you check it back, later at this website : http://www1.shopping.com/mitsubishi-tv-wd73732dlp-parts/products~FD-0~PG-3
Regards
Mitsubishi... | Answered on Jan 20, 2011
Mitsubishi WD-73732 73" Television Logo
43 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
after tv all fine after 30 45
  • Televison & Video
