20 Most Recent Philips Cineos HTS9800W System Questions & Answers
2answers
Info on the SW9800 Subwoofer
I would like to buy your subwoofer for my broken system. Please contact me ASAP
[email protected]
7/4/2018 10:47:57 PM • Philips Cineos... • Answered on Jul 04, 2018
2answers
I have a Philips Cineos HTS9800W system and the
i buy your junction box
[email protected]
7/12/2017 4:02:45 PM • Philips Cineos... • Answered on Jul 12, 2017
Is there a universal phillips remote that will work the cineos hts 9800 hone cinema system
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
12/4/2015 1:13:44 PM • Philips Cineos... • Answered on Dec 04, 2015
0answers
0answers
0answers
Wr9800/55
Be the first to answer 5/8/2013 5:38:13 PM • Philips Cineos... • Posted on May 08, 2013Be the first to answer
0answers
0answers
Lg tv hts9800w
What have you tried? Is there any sound at all?
10/29/2012 11:02:34 PM • Philips Cineos... • Answered on Oct 29, 2012
0answers
2answers
I have a philips cineos
Hi,you have lost vertical deflection.
Possible causes are----
Vertical amp chip needs re soldering.--- very common !
Vertical amp chip has failed and needs replacing !
Failure of electrolytic capacitors in vert circuit
Failure of resisters that supply volts to the vertical circuit
Failure of deflection yoke ( not very common )
Hope this helps
NOTE . If you come across the two knobs that the other dude mentions let me know. I am sure that my fellow Tv techs would also be fascinated to learn of their existence.
The problem you are describing appears to be a vertical circuit problem. The most common problem has been bad solder connections on the vertical output IC. If you inspect the PC board around the vertical ic, you can sometimes see the bad connections. Or the vertical IC and the associated capacitors in the circuit can be the culprit. Average cost to repair should be around $100.00 "
3/27/2011 9:46:52 PM • Philips Cineos... • Answered on Mar 27, 2011
When playing a disc voices are destorted
Are the speakers correctly connected and assigned, particularly the Center? Perhaps it's blown or damaged. Swap another speaker into that slot (Page 16) and the center into another connector as a temporary test to prove if the speaker itself is/is not the problem.
http://www.p4c.philips.com/files/h/hts9800w_37/hts9800w_37_dfu_eng.pdf
3/24/2011 12:44:32 PM • Philips Cineos... • Answered on Mar 24, 2011
Philips Cineos HTS9800W System Logo
51 questions posted
Top Philips Audio Players & Recorders Experts
Steve Mason
Level 1 Expert
David Shaub
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
system keeps going black white
  • Audio Players & Recorders
