20 Most Recent
Icom IC-R8500 Base Scanner Questions & Answers
NO audio signale
l would first check for audio from the external speaker connection which most have.
Power inverter on ic-r8500
wow thats a great radio, pack it up and send it to me.(just kidding)you might want to contact icom
www.icomamerica.com and talk to their techs about this one. congratulations on having one fine radio, it is worth a quality repair,ive wanted to take one of those apart for years lol
Audio problelms
Bad Solder Connections on The Main Board(Look for Ring Breaks)
Model 718. Why is CW mode kaput?
There are a few possible reasons why your radio might not be transmitting in CW mode. One possibility is that the keyer chip has gone bad. Another possibility is that there is a problem with the power supply. If you have a multimeter, you can check the voltages to see if they are within specification. Finally, it's also possible that there is something wrong with the antenna connection. Make sure that everything is securely connected and that there are no loose wires. I hope this helps!
