20 Most Recent Motorola TalkAbout T5000 2-Way Radio Questions & Answers
Look for your user guide here to find the answer http://shop.giantintl.com/Manuals.asp?offset=30
Motorola... | Answered on Dec 17, 2015
http://shop.giantintl.com/Manuals.asp?offset=30 Check your programming to be certain both radios match one another
Parts are not available for this model radio. Speakers generally are damaged from debris or moisture getting into the speaker. They are especially susceptible to small metal fragments due to the magnetic properties of the speaker.
Here is a link to the user guide page http://shop.giantintl.com/Manuals.asp?offset=30
On many TalkAbout radios you can shut off the beeps by holding the PLUS button while turning the radio on.
yes, but no. The radio is designed for low power and a short antenna to limit range. This was to reduce interference with Licensed FCC radios. Since I will provide a few ideas, these are to experiment with radio waves, NEVER to break the law. So.....ideas to increase antenna: most simple, tape coax to the antenna lead. It will pick up a small amount of the radiated signal and sent it to the longer antenna. Strip the rubber and even the mesh, the center copper sends the signal. Best if under 10 feet. Other than this, you either cut open the rubber antenna or best of all, open the radio and soldier to the antenna connection on the main board. Remember: low power radios cannot send a signal far. Use good quality coax, RG58, never cable TV coax. Short length has a better opportunity of working. 30' you will lost all the signal in the coax. Other ideas? Yep, lots. email us. :)
Motorola... | Answered on Jul 01, 2015
check you settings in the radio,follow your instruction manual for the radio
Motorola... | Answered on Jun 14, 2015
Check your programming, it sounds like your Code is not set the same between the two radios. Here is a link to the user guide http://shop.giantintl.com/Manuals.asp Choose your model from the page or the pulldown.
Motorola... | Answered on Jan 08, 2015
It is best to contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
Motorola... | Answered on Aug 19, 2014
TURN OFF AUTO PTT
Motorola... | Answered on May 20, 2014
No polarity. The adaptor puts out AC , low voltage. Just traced the schematic and found out.
Motorola... | Answered on May 17, 2014
Vox means voice activated, as you speak, it should transmit
Motorola... | Answered on Apr 08, 2014
Couldn't find the user guide for the T5000, but did find the T4900 and the T5100. You might try looking in them to see how to restore your settings. Not all TalkAbout radios seem to have a quick reset function. You may need to restore the unit by taking it back to a basic mode. Shut off special features such as your Interference Eliminator Code, VOX, Qt filter, Call Alerts, etc.
Here is a link to the T5100 user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Here is a link to the T4900 user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4800_UserGuide.pdf
Best regards.
Motorola... | Answered on Mar 27, 2013
A few items to check:
Be certain both radios are set to the same:
Frequency
Qt filter
For a simple test set the Code, Qt filter, and any other special features to off or zero. This will allow you to find out if the radios will work simply on their frequency. Once you establish this, you can add in the features as you need them.
Here is a link to the T4900 & T5100 user guides (couldn't find T5000 alone.):
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXx_User_Manual_E.pdf
Best regards.
Motorola... | Answered on Jun 27, 2012
Motorola TalkAbout T5000 2-Way Radio Logo
56 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
possible put longer antenna
  • Radio Communications
