20 Most Recent Digidesign Mbox 2 Barebone Questions & Answers
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Digidesign Mbox ... | Answered on Apr 16, 2019
Digidesign has a Windows 7 (Pro Tools 8.03) update now.
Digidesign Mbox ... | Answered on Feb 02, 2016
Workshop. Is this a word association game?
Digidesign Mbox ... | Answered on Oct 13, 2013
When you say a session is it opening to the login page and terminating and shutting down?or where is it stopping? Have you tried opening on safe mode? If it opens on safe mode go to control panel under users and add a user with admin rights after that log off and login with the new account and you can transfer any personal data from one profile to the new one. Once done go under control panel and delete the entire bad profile. Once completed restart. If its on windows boot, you might need a windows disk to fix.
Digidesign Mbox ... | Answered on Apr 15, 2013
The easy way round this is to increase the amount of RAM in your machine. I would suggest at least 3 GB and use the fastest ram you can fit (check the spec of your machine for the memory type [DDR2 or DDR3], max speed and how much ram your board will take. If your Windows OS is 64 bit you can fit the max amount your machine can handle)
Digidesign Mbox ... | Answered on Sep 19, 2012
They will only work when something is plugged into them.
Digidesign Mbox ... | Answered on Jun 04, 2012
Well it all depends on what program you are using to record your music you will need to activate the noise reduction filter. or lower the volume on your mic but not on the program. Therefore your mic will not pick up any noise in the background and you will still have the same music quality.
Digidesign Mbox ... | Answered on Apr 27, 2012
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
free
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware.
SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software.
Hope it helps
Digidesign Mbox ... | Answered on Oct 14, 2011
You need Protools software before you can do anything with it. Find it here: http://shop.avid.com/store/category.do?category=protools-upgrades-new . Then connect the usb or firewire cables and you can start jammin.
Digidesign Mbox ... | Answered on Jul 16, 2011
You can find the latest drivers and software for your Digidesign Mbox 2 from the manufacturer's website at avid.com.
Digidesign Mbox ... | Answered on Jul 08, 2011
Hi rfanklin65,
Did you remember to save the audio file folder to the disk as well as the session data? If so, are the audio files on the same disk as the Pro Tools sessions?
Are you running a Windows or Mac system?
Thanks, Krisfaudio
Digidesign Mbox ... | Answered on May 04, 2011
Welcome to Fixya. I would like to know when you connect the Protools LE on your Windows 7 computer does it tells you that it has found a new hardware or installing device driver?
It if does it only means that the Protools LE is detected however you need to install the latest driver on it. If it is not detected then try another usb port. Incase you need the driver for your Protools I've provided the link of the download page of the latest driver of Protools
ProTools Driver Download
Note: When you connect the device to the computer it should be detected even if you dont have the driver. You can also try to use a different USB Cable if it is possible just to check if the problem is within the cable.
If you have questions please let me know. Thanks for using Fixya.
Digidesign Mbox ... | Answered on Apr 10, 2011
I had this problem as well... If this is a 2011 macbook pro you have os 10.6.7 which is not supported by avid at this time. We actually need to down grade to 10.6.6. You installation cd with your macbook pro is 10.6.6, so you'll need to install that, then go to the avid website and download pro tool le 8.0.5. Everything should work fine just don't upgrade to 10.6.7 until it has been approved by avid. If you need detailed steps look at the avid forum for pro tools. Step to uninstalling and installing the os can be found on youtube.com... Do not have your mbox plugged in when you install pro tools. I hope this helps!!!
Digidesign Mbox ... | Answered on Mar 29, 2011
Digidesign Mbox  2 Barebone Logo
Popular Tags
68 questions posted
Top Digidesign Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Digidesign Computers & Internet
Most Popular Question
running digi 001 windows 7
  • Computers & Internet
