20 Most Recent
Cardo scala-500 Wireless Headset Questions & Answers
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
- ensure the bluetooth setting is turned on on the handset
- switch on the scala 500
- press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
- now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
PIN Number
Most of the time 0000 is the code. I hope this helps, Mike
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
