20 Most Recent
Sony DRX-830U (027242700338) DVD RW Dual Layer Burner Questions & Answers
Lost instuctions to back up photo,s
Download BurnAware free burner software. Run it. Select Data DVD. Insert a blank recordable DVD in your drive. Add the files you want to backup (photos, music files, documents, etc) and then click on the red Burn button. These files will be burned onto the DVD.
Lost instuction manual to back up toshiba laptop
Try using BurnAware free CD/DVD burning software. You can select the files you want to backup and burn them as a data disk.Doing a full backup of a computer will copy all applications and data and will consume many DVDs. All you really need to copy is your data, such as your photo folder, music folder, email folder, etc.
The door won't open.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps don
Write error on first write
HI Robert,
Download and install CCleaner
(free) from Piriform
Run the cleaner to remove old
un-needed temp files
Select the StartUp tab and look
for any programs that you know you installed but no longer use or
need, and disable them. Caution, do
not disable any system files unless you absolutely know what they
do and that you do not need them.
Run the Registry cleaner, when
asked if you want to backup the registry, select YES,
and save to a file you will remember just in case. I have used this
program hundreds of time on many different system and it has never
caused a problem, but you want to be safe, backup the Registry.
If asked about a particular file
that it wants to clean, select "yes to all"
Reboot
Windows should reinstall the drive when
the computer boots back up.
If this does not resolve your problem,
try the following.
If you take all these step and you
still can not burn a DVD, chances are your DVD burner needs
to be replaced. Good Luck.
I can not get the unit to recognize or burn dvd
Have you tried this on another computer and does it work then? If not try that first. Secondly, disconnect all other usb devices as it may be that you are draining too much from your usb hub which means the dvd drive won't function or will function abnormally. Also check your firmware by visiting the manufacturers website. Give these a shot then get back to us to let us know.
Best of luck
IHOOK UP THE BURNER TO MY COMPUTER BUT NOTHING
Try a different USB port. Check if other USB devices are found when in that port.
Unplug other USB devices (keep your keyboard and monitor attached) and check if the device is recognized. Since you indicate that you used the front port, you may want to check that the cable between back of the port to the motherboard is fully seated on both sdes. Make sure that the OS hasn't been set to turn off the previously unused USB ports (this is a security and power-saving option).
I hope this helps.
Drx-830u not responding
I an sorry to say but it appears ya drive has gone faulty :( I have seen this a number of times at the shop.. If ya have a stuck disk it can be gotten out by using a straightened paper clip and inserting it into the hole in the front of the drive, and by pushing it in the drive door will be opened.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
