20 Most Recent Amana AOGD2750 Gas Double Oven Questions & Answers
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Amana AOGD2750... | Answered on Mar 27, 2017
the membrane has tiny conductive traces within it and each button completes a different circuit when it is pushed, the traces cannot be revealed without mutilating the touchpad beyond repair...
Amana AOGD2750... | Answered on Apr 22, 2016
Try a local independent appliance parts store. They may still have it in stock. Check your phone book under appliance repair/parts.
Amana AOGD2750... | Answered on Mar 19, 2015
You will need to replace the ERC module Pn 31799201: expensive $199
Amana AOGD2750... | Answered on Dec 06, 2011
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Amana AOGD2750... | Answered on May 14, 2011
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Amana AOGD2750... | Answered on Mar 27, 2011
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Amana AOGD2750... | Answered on Mar 13, 2011
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Amana AOGD2750... | Answered on Jan 28, 2011
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Amana AOGD2750... | Answered on Nov 22, 2010
HI,
When the power outage happened was there anything being cooked in the oven. Please disconnect the power cord coming from the oven to the wall socket and press the cancel button a couple of times. reconnect the cable and check. the oven should come on if its minor conflict , otherwise it would require more troubleshooting
Thankyou for using fixya
Proton
Amana AOGD2750... | Answered on Sep 13, 2010
F1=Electronic range control failure
It is telling you may have a faulty control...need to replace control or EOC
Thanks
Amana AOGD2750... | Answered on Jul 13, 2010
Amana AOGD2750 Gas Double Oven Logo
54 questions posted
Top Amana Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Amana Oven Expert? Answer questions, earn points and help others
View Most Popular
Amana Ovens
  • Amana Ovens
Most Popular Question
glow stick comes but oven will not light
  • Ovens
