20 Most Recent
HP Pavilion s3020n (882780985063) PC Desktop Questions & Answers
No power on self test
First
to be check is your power supply. Used power supply or brand new ones,
does not matter as long as it is working properly, with correct voltage
and ampere rating. Check your power supply with a voltmeter. Please take
note also the total watts you need.. If your power supply is running
good, problems will go down the line, the Motherboard. Remove all
devices (hard disk, cards, memory, etc) just the motherboard, just to
see if the motherboard is working right. Your should be hearing a beep
sound indicating that the board is alive. If yes, you may reinstall the
rest of the devices you removed.
My HP pavilion wont start up.it will sometimes but
Check the power supply. You can do this by opening up the case and hitting the power button. If the fan on the back of the power supply and the fans internal in the unit all turn of then it is not a power supply issue and is a motherboard issue. This seems to be a power supply problem and will be around 100 dollars if you fix it yourself
How do i remove the dvdrom drive in my hp pavilion slimeline pc.
The DVD drive has to come out the front of the tower. To remove the front panel there are 4 snap tabs that allow you to pull the front panel off. There is a sequence to this. First you have to remove the media bay by pushing the black tab on it and sliding the bay free. Next comes the HD, raise the snap bar and removing the one screw securing it right beside the snap clip. Unplug the connector labeled P3 and the HD will slide straight out. Now you can access the snap tabs for the front panel. Once the panel is off there is one black screw just above the HD bay that needs to be removed. Disconnect the 2 cables from the DVD drive. On the opposite side of the DVD drive theres a tab that you need to push outward and the DVD will slide out the front.
Cant Remove Optical Drive to add memory
At HP's web site, the instructions mention removing a screw on the side of the CD to remove it from the box. Try looking
here. (If that link doesn't work, go to www.hp.com and in the search window, enter S3020n. Click on Help & Troubleshooting, then Setup and Install, then Adding & Removing Hardware. There's a link to replace the CD there. They also have PDF versions of the manuals.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
- the wifi card is missing, as was super common 10+ years ago.
- someone put in the wrong card, not from HP list
- HP blacklists (bios blocks) none HP cards (wifi)
- the card needs a driver to work if not it is dead or 1/2 dead.
- the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
- The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did
google bios update bricked my PC and cry.
why are you here and not at HP.com
only they can recover bios.
they changed the rules now 10 time.
so only they know this, and are pain to deal with.
UEFI is the enemy here, new rule and regressive as can be.
in fact all new PCs can not be regressed, and some old now
they even delete the 20 version of bios there, to force that.
not saying they did that to your PC, but keep that in your head on all HP PC.
the last bios upgrade stated, no going back.
the Cntrl_+B might work , the flashback bios trick\
in your manual if you read it.
