20 Most Recent
Technics SL-BD20D Turntable Questions & Answers
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
5/30/2014 10:41:44 PM •
Technics...
Answered
on May 30, 2014
Need aground cable
The ground cable is usually a part of the audio cable. A red lead(right channel) and white lead(left channel) and a black lead. If there is no black lead, you can connect any wire to the metal portion of the turntable and the ground lead on your receiver. For more information, or should you have further question, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
12/18/2013 12:18:32 AM •
Technics...
Answered
on Dec 18, 2013
Turntable will not turn
There is really nothing else to it. If the drive belt is in tact, and properly installed, and the spindle motor is rotating properly, your turntable should rotate. There's nothing else that rotates the platter. Just make sure the belt is wrapped around the spindle motor.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
12/18/2013 12:14:01 AM •
Technics...
Answered
on Dec 18, 2013
Wont change speed
Hi, platter needs to be rotating when you change speeds. Cheers john. Styluscity
11/24/2013 10:46:55 PM •
Technics...
Answered
on Nov 24, 2013
Needle skating badly; Can I adjust the stylus
Too causes of this problem. One the stylus is worn out. Two not enough pressure to the stylus. At the end of the arm is a weight this should move up or down. If you can see numbers on it increase it slowly to the higher numbers, trying it as you go. The trick is to apply the correct weight to keep the stylus in the grooves and not here a rumbling sound from too much pressure.
7/4/2011 3:07:06 PM •
Technics...
Answered
on Jul 04, 2011
I dont have the orginal
You don't need the original ground wire for Technics
SL-BD20D turntable,
any plain cable can be used for this purpose...
you should connect turntable to your pre amp,should be a "phone" input at the back...
here are some suggestions for grounding....
Plug in a surge protector to the outlet, and then plug all the components into that surge protector
Connect a ground plug to the
surge protector and then plug the ground plug into the main outlet. A
ground plug is available at any hardware store, and turns a three prong
connection into a two prong. Ground plugs help eliminate 60 cycle hum.
Connect the ground wire from
your turntable to the ground wire connection on the receiver. If this
doesn't work, looking on the back there should be a grounding point,
Unplug your
receiver.. Split a wire and attach one of the splits to the receiver
where you will see the text, "ground" or something similar. Attach the
other end to something metal such as a pipe that goes into the ground.
Secure with electrical tape. Plug in.
connect the ground wire to a screw on the electrical
outlet.
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
6/22/2011 7:37:19 PM •
Technics...
Answered
on Jun 22, 2011
I have a technics slbd20d
u mean the recor speeds and slows down? if its an older turntable there is some play in the bpms thats why most people get direct drive. my sugguestion is to look it over and tinker w things but dont break it. im sure you can find a manual online
5/6/2011 12:52:44 AM •
Technics...
Answered
on May 06, 2011
I have a technics sl-bd20d
Poor ground at the phono cartridge. Turn your receiver off and remove/reseat the cartridge and/or the tiny leads to it.
4/3/2011 11:14:02 PM •
Technics...
Answered
on Apr 03, 2011
