20 Most Recent Sony KDS-60A2020 60" HDTV Questions & Answers
3answers
Kds-60a2020 parts ..where to buy???
You can buy all required parts for Sony KDS-60A2020 TV from Part Store.
Click that link to see list of available parts. Philips lamp for this TV is also there.
Thanks.
10/27/2018 3:32:33 AM • Sony KDS-60A2020... • Answered on Oct 27, 2018
Sony KDS-60A2020 Projection lamp was replaced
there is a menu item for lamp replacement, that's where you turn the message off
11/16/2017 1:06:33 AM • Sony KDS-60A2020... • Answered on Nov 16, 2017
Sony TV kds60a2020 replaced lamp
have you tried making sure the lamp door is closed ... generally 3 blinks means the lamp door is not closed the door pushes a switch closed
2/14/2016 4:07:58 AM • Sony KDS-60A2020... • Answered on Feb 14, 2016
I have a sony kds 60a 2020 the red light blinks 3 times. What does that mean?
This is a lamp issue. Reseat the lamp and if that does not fix, replace.
12/22/2014 3:12:36 PM • Sony KDS-60A2020... • Answered on Dec 22, 2014
Sony no power
Replace the Bulb. You can get one at Amazon.com for less that $50.
9/8/2014 1:33:37 PM • Sony KDS-60A2020... • Answered on Sep 08, 2014
What does it mean when upon power up the green light comes on for about 15 sec. Then clicks and blinks 3 times red. What does this mean?
I was having same problem this is what I did get a can of dust off take the back of tv off and clean the fans blow them out real good try that see how it
8/28/2014 11:49:25 AM • Sony KDS-60A2020... • Answered on Aug 28, 2014
2answers
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block. It is quite involved to replace, if not technical get professional help.
5/15/2014 2:27:11 PM • Sony KDS-60A2020... • Answered on May 15, 2014
LIkely a bad main boards or SMPS board.
5/8/2014 4:04:31 AM • Sony KDS-60A2020... • Answered on May 08, 2014
0answers
2answers
I am trying to get information on which part
XL5200 FOX has them $129.00 1-800-227-5369
2/18/2014 2:33:39 AM • Sony KDS-60A2020... • Answered on Feb 18, 2014
TV will not turn on.
Sounds like there is a short in the tv somewhere, the clicking is probably a breaker/fuse inside the tv cutting power to prevent damage to the components. Have you tried a different outlet as they can sometimes cause this to occur by surging power to the unit.
12/4/2013 1:21:49 PM • Sony KDS-60A2020... • Answered on Dec 04, 2013
Need to reset lamp replacement
Under your TV menu, advanced options or diagnostics.
11/5/2013 12:08:59 AM • Sony KDS-60A2020... • Answered on Nov 05, 2013
manual
Our Sony KDS-60A2020 (2007) is losing sound. When turned on we have sound, but after a while the sound will gradually fade to nothing. The sound will recover but only after jarring the TV with a few
its more than likely a solder issue near the audio out IC. Unless your good at soldering you will most likely be better off replaceing the board yourself. You shoud be able to get the boards for that model along with free tech assistance from www.tvrepairworld.com
3/23/2013 12:29:06 AM • Sony KDS-60A2020... • Answered on Mar 23, 2013
Sony KDS-60A2020 60" HDTV Logo
92 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kds 60a 2020 red light blinks 3
  • Televison & Video
