20 Most Recent Amana ARGS7650SS Gas Kitchen Range Questions & Answers
Oven does not work
First off check to be sure there is 120 volts at the wall outlet as this controls everything and may be as simple as a breaker or fuse. If that's okay then the igniter is the most commonly defective part and has two main functions. First,it draws electrical current through the oven safety valve to open it. Second, when it gets hot enough to glow it ignites the gas in the oven burner. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the it glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
5/15/2017 12:40:09 PM • Amana ARGS7650SS... • Answered on May 15, 2017
My pressure regulator needs to be replaced and the original part # is no longer available. is there another regulator that will work ?
-Take it out. It should have part number on it. If so then search that number trough the web site or amazon.com. Possibly you'll have luck. Good luck Mai
8/28/2015 5:45:39 PM • Amana ARGS7650SS... • Answered on Aug 28, 2015
The oven door is locked after pushing clean button.
Flip the breaker going to the oven and it will release.
10/16/2014 5:22:52 PM • Amana ARGS7650SS... • Answered on Oct 16, 2014
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
10/15/2014 2:11:15 PM • Amana ARGS7650SS... • Answered on Oct 15, 2014
How many cubic feet is this model of Amana Range?
actual oven space? Never had anyone ask that before. Even manufacturers don't list that info. Why not just measure depth x width x height (of oven cavity) in inches and multiply to get an estimated total of square inches. Then divide by 144 (the number of cubic inches in a cubic foot).
8/24/2014 3:09:07 PM • Amana ARGS7650SS... • Answered on Aug 24, 2014
Does the top of amana open
Yes it WILL lift up. Check on the manufacturers web site for the instruction manual for your model.
7/24/2014 12:20:54 AM • Amana ARGS7650SS... • Answered on Jul 24, 2014
0answers
On my Amana gas range 2 ignighters work an 2
Hi.
Either the single ignitors are faulty, or the ignitor sparker module must be replaced.
The sparkers are tested energizing them.
The ignitor hub module is located under the cooktop panel.
Check also the wiring harness to spark module.
Here all parts and diagrams for your range.
Regards.
6/9/2014 3:39:37 PM • Amana ARGS7650SS... • Answered on Jun 09, 2014
3answers
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
12/17/2013 3:09:54 PM • Amana ARGS7650SS... • Answered on Dec 17, 2013
Amana ARGS7650SS Gas Kitchen Range Logo
206 questions posted
Top Amana Kitchen Ranges Experts
Paul Carew
Mike
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Kitchen Ranges
Most Popular Question
oven door locked after pushing clean
  • Kitchen Ranges
