20 Most Recent Black & Decker Compact Power Screwdriver Questions & Answers
The chuck wont tighten
The outer sheath of the chuck turns a thread on the back of the jaws in the chuck and it it is not tightening correctly then the jaw threads have been broken/cracked or the jaws have been stressed out of alignment and are not longer closing in a parallel manner. Best replace the chuck as they are generally not repairable.
8/2/2013 8:04:59 AM • Black & Decker... • Answered on Aug 02, 2013
2answers
Drill wont tighten to drill holes
chuck problem replace it,
6/15/2012 9:36:55 PM • Black & Decker... • Answered on Jun 15, 2012
Hi how do u change
you dont there is a plug in to charge it. usually a pin style
12/20/2010 12:45:42 AM • Black & Decker... • Answered on Dec 20, 2010
2answers
Black & decker pivot driver cordless
hello sir
8/23/2008 3:58:04 AM • Black & Decker... • Answered on Aug 23, 2008
Drill
there are no breakdown for the said model
6/17/2008 9:10:12 PM • Black & Decker... • Answered on Jun 17, 2008
Instruction manual
see dewaltservicenet look for search info & type in model #
5/29/2008 11:16:09 PM • Black & Decker... • Answered on May 29, 2008
2answers
Black decker drill
If the problem is with very small bits 1/16" for example, the chuck could be defective in either design or manufacture. I have had this problem with a cordless model FS1800D. Waiting on a replacement chuck.
5/29/2008 11:15:05 PM • Black & Decker... • Answered on May 29, 2008
3answers
Beginner
First of all, congratulations on your new place! I think this box is pretty useful for beginners: http://fadisel.com/Producte.aspx?referencia=1090
Let me know if you need further help, and good luck!
Burke.
5/27/2008 4:55:40 AM • Black & Decker... • Answered on May 27, 2008
Black & Decker Drill (Motor does not work on Forward switch but it is ok on reverse)
Scraped the drill and bought a new one for $20
5/14/2008 8:33:53 AM • Black & Decker... • Answered on May 14, 2008
Black & Decker
how to release the bit
12/16/2007 7:23:33 PM • Black & Decker... • Answered on Dec 16, 2007
How do i refill a finishing sander
Without any more detail about your particular finishing sander, I do not know whether this will help, AND I am no expert, but here goes ...
I inherited a Black and Decker 1/3 sheet sander, with no manual, from my late brother. It is not their newest model -- from the yellow plastic and the general looks and wear, I would say it is from the 1980s or 90s. The sand paper is held by a sort of spring clamp at both the front and back. There is a slot -- perhaps half an inch wide and a quarter inch tall -- in both of these spring clamps. I inserted a wide-bladed screwdriver into the slot, and pryed away from the sanding pad to open the clamp and insert the new 1/3 sheet.
Hope this helps!
11/28/2007 5:01:47 PM • Black & Decker... • Answered on Nov 28, 2007
The blade on my black and decker radial arm saw is locked up. It will not move even by hand.
moved you out of cars to tools well some have brakes, so hands not cut off, as it spins down. what is the job here. not told what ACT is being attemped or if you lost the manual that covers all this. some blade bolts are LHT , left hand treading so , learn that first if doing blade swaps. buy this used and need to learn how to use it? NO MODEL SAW TOLD at all, nor country told, some are different outside our USA< so not told. is this the blade spin locked up, NOT TOLD add more words or tell what your are attempting/ I guessed blade but gee I do no know what's up here
10/12/2022 12:54:15 PM • Black & Decker... • Answered on Oct 12, 2022
Black and Decker 5000k how to disassemble the bottom part. The orange and black mouse
There are no repair parts available. Hate to tell you but is a dispoable sander.
4/24/2017 7:00:44 PM • Black & Decker... • Answered on Apr 24, 2017
Gears in the black and decker cordless screwdriver
are not replaceable throw it away
11/26/2014 1:45:30 PM • Black & Decker... • Answered on Nov 26, 2014
I need a replacement 24 v battery charger for my
Call Alltrade customer service representatives at 1.800.423.3598. they own Allegheny. have model number ready
4/29/2014 6:04:54 PM • Black & Decker... • Answered on Apr 29, 2014
My Black & Decker electric weed-eater only
The bush/bearing behind the trimmer head is probably rusted or worn out and the motor is poling out and creating a short situation. Not much can be done so it may be best to junk it and get a new one.
8/2/2013 9:48:26 AM • Black & Decker... • Answered on Aug 02, 2013
Want to register a new
get the warranty card out of the box or from the back of the user hand book and fill out all the relevant details and post if off to the manufacturer. Or you may be able to down load from the manufacturers web site a pdf form for the registration.
8/2/2013 9:45:02 AM • Black & Decker... • Answered on Aug 02, 2013
How long should a cordless 18 volt trimmer/edger
It depends on the age of the battery.
6/8/2013 3:38:10 PM • Black & Decker... • Answered on Jun 08, 2013
How do I use the centre-tech stud sensor
Go to Yahoo.com and type in the manual you are looking for.
6/8/2013 3:33:24 PM • Black & Decker... • Answered on Jun 08, 2013
Black & Decker Compact Power Screwdriver Logo
14 questions posted
Top Black & Decker Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Hand Tools
Most Popular Question
beginner
  • Hand Tools
