20 Most Recent Amerock 3 Ring Knobs - BP1586 Questions & Answers
I know I don't need to mention that knobs with an emergency release inside the house are wonderful things. Many function by sliding a nail into a hole in the middle of the door knob, others use the push/turn technique.
First thing to try is pushing the door knob in and then pulling it out while turning it as far as you can in both directions. If a part is worn out or misaligned, sometimes this is just enough to do the trick. If that doesn't work:
Now that the pins are out of the hinges, try working with another person if you can. Don't concentrate all of your efforts on the latch if you haven't been able to access it because of the moldings. Hinges get sticky and may need a good nudge.
Have one person push the door up from the bottom or top with a small pry bar or large screw driver. While this is happening, watch the hinges. They fit together like a jig saw puzzle, there should be play and they will loosen up a bit now. Now you will have an idea of the best way to try this.
Remember, the hinge side is no longer attached, so caution is in order. If you are working from a side without molding, pull out from the bottom and/or top while lifting gently with the pry bar. You can sometimes use a fulcrum and step on the pry bar if you are alone.
If molding is blocking your side, try pushing the hinge side inward. If that doesn't work, Using the pry bar, go to the bottom corner on the door knob side and tilt the door toward the opposite corner as much as possible.
If you can, jam something as sturdy as possible (screwdrivers)above and below where the latch is. With another screwdriver of tool, push directly into the latch and push the handle of what you are using in the direction opposite the door. Give it a good yank.
Try to be observant and creative while doing this. You are looking to try and squeeze out just a little more space. Use any area where you see play. Underneath, along side, up top, where ever.
There will undoubted be some damage to the wood or paint, remove the molding piece alongside the latch. It will be affordable to replace if you are a diy person.
For the others that commented, parts inside get worn and as mentioned above, the shaft has to be aligned correctly. If not, you run into problems like the latch not fully engaging.
Cutting the knob off will be a bit difficult. Even when that is done, it may be difficult to remove the latch and metal burrs are razor sharp. I think I would call a handyman before attempting that. Good luck all.
Amerock 3 Ring... | Answered on Jun 04, 2018
Now you can put your standard screwdriver in the hole in the middle of the metal where you removed the doorknob, turn the screwdriver, and now your door will open.
Jen
Amerock 3 Ring... | Answered on Feb 12, 2015
f the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Amerock 3 Ring... | Answered on Aug 11, 2014
If all else fails...take pins out of hinges and remove door to get to lock bolt.
Amerock 3 Ring... | Answered on Nov 28, 2011
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Amerock 3 Ring... | Answered on Oct 20, 2008
Most of the time all you need to do is swap the two handles and flip the latch over so the angled part of the latch is on the other side, so it will self latch when you close the door.
Amerock Hardware... | Answered on Jun 15, 2018
Have you tried calling AmerlockForLess.com for assistance? On their website they say: "American customer service reps by phone from 8:30 to 5:00 M-F. Our toll free number is 1-877-261-5805."
Amerock Hardware... | Answered on Apr 07, 2018
Look for a small hole or slot on or around the handle, Push a pin inside to unlock it.
Amerock Hardware... | Answered on Feb 12, 2015
If you can take the lock off the door push a small metal piece inside the lock from the back to push out the broken key. If unable to take it off, get an old windshield wiper, remove the stainless steel supports from the wiper (long skinny piece of metalt holding rubber blades in place). Grind or file an angled tooth into the end of one. Insert into lock (tooth down) so it catches on the teeht of ghe broken key, pull rod and key out.
Amerock Hardware... | Answered on Aug 29, 2014
You will have to carefully drill them out. Start with a small bit and slowly work up to a bigger one as you go once most of the head is drilled out the latch should pull off, you can then use vice grips to unscrew the remaing part of the screws.
Amerock Hardware... | Answered on Aug 11, 2014
25.4 x 5
Remove lock from door.The round part contacting door usually spins to accommodate different width doors. This will pull the assembly together.
Amerock Hardware... | Answered on Jun 25, 2014
Amerock 3 Ring Knobs - BP1586 Logo
Popular Tags
14 questions posted
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Amerock Hardware & Accessories
Most Popular Question
sitting room door closed
  • Hardware & Accessories
