20 Most Recent Dewalt DW8306 36-Grit. 4-1/2" Blue Zirconia 7/8" Arbor Resin Fiber Disc Questions & Answers
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Dewalt DW8306... | Answered on Aug 27, 2008
Full strip down, clean and lubricate. Don'y use WD40! Replace motor brushes.
Sand is exceedingly abrasive to moving parts. But you know that :>)
Dewalt Saws | Answered 10 hours ago
Considering the average domestic quality power drill has a design life of about 10 hours your saw probably isn't doing too badly.
I don't have a wiring diagram but the series-wound brush type motor hardly varies regardless of it's application. These motors are electrically very noisy and a high powered version is perpetually almost at the point of self destruction and so to prevent radio frequency interference they have to be heavily suppressed and suppression also helps protect the motor from itself.
Some manufacturers use discrete components for this purpose but some use a single component that is a network of capacitors and inductors, that necessarily is compact and therefore highly stressed and these do fail sometimes.
As a saw doesn't usually have a speed control, all the components can be checked for continuity with a multimeter unless it is fitted with a soft start, the testing of which is beyond the scope of home testing. If everything else is found to be ok the problem is likely with the soft start (if fitted).
The current usually flows through a series wound motor from the switch to a field coil, through the field coil to an armature brush, through the armature to the other brush and then through the other field coil to the neutral. There can be slight variations to this but basically the armature is in series with the field coils.
If you have power to everywhere except the brushes it would suggest a break in a field coil which is very unusual...
No power to the brushes would mean no power to one of the field coils which would mean you don't have power everywhere.
I suggest you begin dismantling and testing again...
Dewalt Saws | Answered on Sep 04, 2020
any multi fit blade
it is only the shank width that may be a problem as some are too wide to fit in the slot
Dewalt Saws | Answered on Jul 17, 2020
I think if DeWalt had included a reset button it would be quite obvious to the user, labelled as such and mentioned in the user manual...
Dewalt Saws | Answered on May 16, 2020
7-inch Turbo Skil 79510c Rim Diamond Blade Skil's range of abrasive blades highlights cutting blade technology supported by traditional production. These cutters edge last extended than cutting wheels in hard materials. 7 In Turbo Rim Diamond Blade.
Pros
  • More extended life than harsh wheels
  • For Circular Saws and Stones
  • For use in all kinds of cement, compact block, stone, and general workmanship
  • Just for dry use
Cons
  • Cons are not found.
Check Today's Price on Amazon
Dewalt Saws | Answered on Mar 26, 2020
Request the diagram from DeWalt.
Dewalt Saws | Answered on Jan 11, 2020
https://www.dewalt.com/products/power-tools/routers-planers-and-joiners/planers-and-joiners/13-in-three-knife-two-speed-thickness-planer/dw735
You have to register to read the information (BAD, Dewalt. Bad dog.)
In general>
Check outlet, try another AC outlet.
Check power cord end to end for damage. Do you have a non-contact AC indicator? (You should) Are you getting AC to the machine?
Check built in fuse or breaker on the tool.
Check the switch, does it feel and sound like it is switching correctly? Or is something different?
Dewalt Saws | Answered on Nov 19, 2019
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Dewalt Saws | Answered on Oct 03, 2019
if you are using thin cutting disk turn arbor nut over. It he shaft is rotating while tightening disc, use shaft lock button on side of gear box.
Page 10 of your instruction manual. Here is a link
DeWalt D28402 Instruction Manual Page 10
Dewalt Saws | Answered on Sep 11, 2019
I think that I have the same model, and yes, I do find the buttons to be of some trouble. In my experience, they can stick, not allowing the leg to collapse. I have to keep them pushed in at the same time collapsing the leg. Look for any burrs or bending on the folding device itself, as it may have gotten bent during a move and needs straightened.
Dewalt Saws | Answered on Aug 06, 2019
Dewalt DW8306 36-Grit. 4-1/2" Blue Zirconia 7/8" Arbor Resin Fiber Disc Logo
1 questions posted
Top Dewalt Saws Experts
efs_perpends
efs_perpends
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Saws
  • Dewalt Saws
Most Popular Question
tile saws question
  • Saws
