20 Most Recent
Irwin SDS-Plus Hammer Drill Bit 6in.L, 1/4" dia., ModelNo. 322017 Questions & Answers
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Sd rotary hammer drill 110 volts bit brocken in
Put some WD40 into chuck and wait a few minutes. Open the chuck as you would do when normally removing the drill while at the same smartly tapping the back of the drill.Alternatively try to grip the broken drill bit with a long nose pliers to extract it. A strong magnet might also pull the bit out.
How to remove oven door Maytag mgr5775qds
To remove the oven door on a Maytag MGR5775QDS range, you can follow these general steps:
- Open the oven door completely to access the hinges.
- Locate the hinge locks on both sides of the door. These are usually small levers or clips.
- Use a flathead screwdriver or your fingers to flip the hinge locks toward the oven cavity, releasing them from their locked position.
- With the hinge locks released, close the oven door halfway.
- Lift the oven door up and off the hinges by pulling it toward you and lifting it away from the oven.
- Place the oven door on a flat surface, such as a table or countertop, to work on it or store it.
Remember to exercise caution when handling the oven door, as it may be heavy and awkward to maneuver. If you're unsure or uncomfortable with removing the oven door yourself, it's always a good idea to consult the appliance's manual or contact a professional for assistance.
2/17/2024 5:19:51 PM •
Drills
Answered
on Feb 17, 2024
How to remove the chuck for Black & Decker 4.5 Amp Drill.
Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 12, 2022
1/23/2024 6:34:51 AM •
Drills
Answered
on Jan 23, 2024
Mighty Max 20v battery charger flashing red and green light
You may want to look for the manual but it is mostly caused by a bad battery. The battery may be discharged far and many chargers are not capable to charge batteries being even close to full. Green means charging and red is fail. It keeps trying. A broken and useless battery may show the same indicators flashing. Inspect the battery to make sure it is in a good condition, like acid at about the right level and no traces of melting on the container or visible loose/bent plates. Put a voltage or multimeter on 20 Volt at its terminals and determine the battery has any voltage to begin with. 11Volt indicates an empty battery and 12,8 to 13,2 is probably full. An empty 12 Volt battery is charged with a 12 Volt ~ 1 Amp power adapter (maximum 1/10 of battery Amp but not until fully charged) and preferably a 1 Amp fuse in the + line. This is "attended charging," meaning things must not get hot and charging is stopped before the battery is full. Then try the charger again, always the 12 Volt clamps attached first and next the plug in the mains. Disconnecting is in reverse order.
Bad batteries often have sulfur on their plates and can be revived by fast discharging but the success rate is low. Meaning a battery can be better but not good enough. Batteries have a life of 5 years and closer to 10 when always charged. When charging was low and often not, the battery could have died after two or three years. This apart from a limited number of charge-discharge cycles. The test is with all lights on and then not dimming in the first minute or after ten seconds. Good batteries must hold charge for a week and not much less every day.
11/9/2023 8:20:26 PM •
Drills
Answered
on Nov 09, 2023
Table for floor drill model dp-16fm
limited info generic answer --try mystery manufacturer --owners manual --online search using make and model fixya doesnt produce or sell products
10/28/2023 4:39:55 PM •
Drills
Answered
on Oct 28, 2023
Need to find a trigger for 20v master craft cordless drill
I have an MC cordless impact drill that isn't as strong as it use to be and laggy when screwing in wood. I took it apart in the hopes of replacing the brushes or see something obvious that would be the issue but unsure if it has or where would the brushes be to replace in first place. Model #054-3175-8
10/15/2023 12:09:43 PM •
Drills
Answered
on Oct 15, 2023
