20 Most Recent
Universal Battery Charger Charges Multiple Combination Questions & Answers
How long does it take to charge batteries?
depending on the type of battery and charger the time usually takes from 6 to 12 hrs. for a full charge. Shorter charging time will result in battery not operating to its full potential
1/14/2013 3:50:31 AM •
Universal...
Answered
on Jan 14, 2013
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
1/22/2011 5:15:52 PM •
Universal...
Answered
on Jan 22, 2011
Charger
next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
1/10/2009 4:27:20 AM •
Universal...
Answered
on Jan 10, 2009
Checking an AC-DC Power Transformer as the cause of a device failure
After a couple of personal experiences, I found that many electronic devices that use a wall plug in AC to DC power transformer ( commonly known as a power brick) are the most common cause of failure to the electronic device they are connected up to.
NEVER just check this for voltage. A power brick can easily show you it's supplying the right voltage BUT lacks the Amperage that your device requires. It's usually the amperage that fails.
THIS IS THE RIGHT WAY TO CHECK A POWER BRICK:
Invest in a purchase of a multi voltage universal power brick from an electronics store or Amazon.
Buy one that has voltage adjustments from 3 - 5 - 7.5 - 9 - 12 DC volts
MOST IMPORTANT that this new brick be rated for 2.5 or 3.0 AMPS ( also known as 2500 - 3000 MaH).
It should also be the type which comes with a variety of tips to plug into different devices.
....Before you declare that your electronic device is no good......
Replace the power brick with the new one you invested in.
Adjust the voltage to the same voltage as what was supplied on the original power brick. Install the right tip to properly plug into your device AND MAKE SURE THAT IT IS PROPERLY POLARIZED. On the orig. brick or on your device it shows the proper position of + and - voltage for proper connection. Usually the center is + but check first.
Don't worry about amperage. A 3 amp brick covers just about every need for different devices and your device will only use what it needs. It will NOT over power your device. But again make sure the voltage is properly set.
Now with the brick plugged into the wall and plugged into your device, power up your device and see if it now works. If it doesn't, it's the device. if it does, it's your original brick going out.
What I do is buy a dedicated power brick to replace my test brick so I can use it again for the next time I need to check something.
You'll be surprised at how many times you can salvage your electronic device by using this simple test method.
Nsm performer classic
If your NSM Performer Classic jukebox is not accepting money and playing music, there could be a few different issues that could be causing this problem. Here are a few things you can try:
- Check the coin mechanism: Make sure the coin mechanism is clean and in good working order, and that the coin chute is not blocked.
- Check the bill acceptor: Make sure the bill acceptor is clean and in good working order, and that the bill path is not blocked.
- Check the credit display: Make sure the credit display is working properly and that it is displaying the correct amount of credits.
- Check the software: Make sure the software on the jukebox is up to date and that there are no errors.
- Check the selection buttons: Make sure the selection buttons are working properly and that the jukebox is able to receive selection inputs
- Check the amplifier and speaker: Make sure the amplifier and speaker are working properly and that the jukebox is producing sound.
If none of these steps resolves the issue, it is possible that the jukebox may be defective and require repair or replacement. In that case, contact NSM customer support for further assistance.
How to delete all in my sony ericsson x10i
To delete all data from your Sony Ericsson X10i, you can perform a factory reset. Here are the steps to do this:
- On the home screen, tap the "Menu" button.
- Scroll down and tap "Settings."
- Scroll down and tap "Privacy."
- Tap "Factory data reset."
- Tap "Reset phone."
- Confirm that you want to delete all data by tapping "Erase everything."
Please note that this will permanently delete all data, including contacts, messages, apps, and settings. It's also a good idea to back up your data before performing a factory reset.
Sky plus wont record and watch another channel at the same time says no signal
If your Sky Plus box is not allowing you to record one channel while watching another and is displaying a "no signal" error, there could be a few potential causes for this issue:
Insufficient signal strength: Make sure that your Sky Plus box is connected to the satellite dish correctly and that the dish is pointing in the correct direction. Weak signal strength can prevent the box from tuning in to channels properly.
Dish misalignment: If your dish is not properly aligned, it may not be able to pick up a signal from the satellite. You can try adjusting the dish yourself or contact a professional to align it for you.
Technical problem with the box: There may be a technical problem with your Sky Plus box that is preventing it from recording and watching different channels at the same time. This can be caused by a hardware malfunction or a software issue.
Subscription issue: Make sure you have the appropriate subscription package that allows you to record and watch different channels at the same time.
Box is full: If your hard disk is full, the sky+ box may not be able to record or watch another channel.
It would be best to check all the above points, if the problem persists, contact Sky customer service for further assistance.
Why is my Sky saying no signal on some channels?
Faulty Satellite Cable
There are all sorts of things that can cause a cable to become faulty like age, condition, and whether it's damaged and weathering/ water ingress. To fix- A new coaxial cable or two new coaxial cables may need to be installed for Sky+ boxes and Sky Q boxes.
Hard drive crashed on tascam dp02
A hard drive crash on a Tascam DP-02 digital recorder can be a major issue, as it can result in the loss of recorded audio files and settings. Here are a few potential solutions below:
Check the connections: Make sure that the hard drive is securely connected to the Tascam DP-02. If the connections are loose, the hard drive may not be recognized by the device.
Reformat the hard drive: If the hard drive is still recognized by the Tascam DP-02, you may be able to reformat it and use it again. This will erase all data on the hard drive, so make sure to back up any important audio files before reformatting.
Replace the hard drive: If the hard drive is not recognized by the Tascam DP-02 or reformatting does not work, you may need to replace the hard drive. You can use a compatible hard drive with the same capacity or larger.
Seek professional help: If none of the above solutions work, it may be best to take your Tascam DP-02 to a professional technician who can diagnose and repair the issue.
It is important to keep in mind that, regardless of the solution, you will lose the audio files and settings that were stored on the hard drive. Backing up your files regularly is crucial to avoid data loss.
reset my Tascam DP o2 - You May Try onces.
To perform a factory initialization of the DP-02 turn the unit off. Hold the Up Arrow and Track Edit while powering the recorder on. You'll get a confirmation screen and then press the Yes/Enter button.
Why won't my cmt-ep505 turn on?
The fuse needs to be replaced then because it has blown on you or it might also be the fact that it was stopped working on you guys and you will need to buy a new one.Or it could be the plug or the power cord.
KEB F5 = DC Bus voltage coming, Control card OK, but Display Power Not found, how do solve this problem.
If you are experiencing a "Display Power Not found" error on your KEB F5 Inverter and the DC bus voltage is coming and the control card is functioning properly, there may be an issue with the display or the power supply. Here are a few steps you can try to troubleshoot the issue:
- Check the power supply for any visible signs of damage or malfunction.
- Check the display for any visible signs of damage or malfunction, such as cracks or loose connections.
- Check the wiring and connections to ensure that they are secure and properly connected.
- Check the F5 Inverter's fuse and circuit breaker to ensure that they are functioning properly.
- Try resetting the F5 Inverter by unplugging it and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the F5 Inverter until the issue has been resolved, as continuing to use it may cause further damage.
