20 Most Recent
Dewalt DW746X 10" woodworker's table saw with rai Questions & Answers
Dewalt miter saw dw716 suddenly
You have tripped the overload switch. It should reset after it cools off. If it does not then there may be a small button, like on the bottom of a garbage disposal. Good Luck!
Dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Zero clearence isert
I'm not sure why the instructions said to change the blade in order to cut the slot. I've made several of the zero clearance inserts (for different blades) and always made the slot with the blade I intend to use it with. Of course, you need to match the inserts to the blades (I just tie wrap them together.
My dewalt d27105 saw keeps blowing a fuse
These saws have a rather large amount of draw on a 15 amp breaker... they should be able to operate on a 15 amp breaker, however nothing else can share that breaker.... and if it is an outside plug (GFI) it will be even more likely to trip. If possible, use a 20 amp breaker...they can be found in the garage where central vacuum plugs in. If this isn't an option then ensure nothing else is on a normal 15 amp breaker, use a heavy gauge extension cord, and the shorter the cord the better.
How do you cut angles on this saw. It was given to
When you are facing the front of the table saw. Right above the Dewalt logo, there is a hand wheel that if you crank clockwise - it will tilt your table saw blade to the angle shown where the hand wheel is.
Dewalt flip saw keeps blowing fuse
common problem with this saw is the brushes when worn down to about half inch, won't go into the brush holder any further and starts to arc against the commutator. eventually the heating will burn out the commutator. a replacement armature will cost you $75 plus shipping.
