20 Most Recent
Xerox 8825 Copier Questions & Answers
How do I clear a
LL-10 code means : Paper transport or Xerographic module are disconnected.
LL' codes can indicate a wide range of problems. Here is a quick list:
'LL-05': Fuser Web end of life.
'LL-06': Fuser web motor not seen turning.
'LL-10': Paper transport or Xerographic module are disconnected.
'LL-12': Drum motor failure.
'LL-21': High Voltage Charge failure.
'LL-22': High Voltage Transfer failure.
'LL-30': Cutter fault.
'LL-41'through 'LL-45': Fuser problems.
'LL-50': Problem with "Bulk Power Supply," which provides 26VDC.
'LL.60': NVM (Non Volatile Memory) failure.
'LL.90': Overtoned condition.
'LL.91': Low Toner problem.
For your problem remove the drum unit and paper tray and reinsert. Check if paper is not inserted properly or there is no paper.If paper tray is proper then check the drum unit.It should be lose.Remove and reinsert drum unit.
((((((* The Module Loop Interlock is a circuit which sees that both the Media
Transport Module and the Xerographic Module are installed (if either is
missing, the interlock isn't made.))))))))------------
This will help.Thanks.Helpmech.
