20 Most Recent Bazooka (EL10190PP) Car Audio Amplifier Questions & Answers
Power on my amps but no signal
More than likely you have burned the outputs up.
2/19/2010 11:27:08 PM • Bazooka... • Answered on Feb 19, 2010
No idea!!
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
9/29/2008 11:27:49 PM • Bazooka... • Answered on Sep 29, 2008
ELA 500.I
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
3/13/2008 9:04:34 PM • Bazooka... • Answered on Mar 13, 2008
Girl has no idea lol
It's likely the amplifier but defective speakers or having speaker wires shorted to ground can cause strange problems also (depending on the way the protection circuit responds).
Disconnect the speakers from the amp and connect a speaker that you know is in good working order. Use a speaker that can handle a lot of power and be ready to switch the amp off quickly or disconnect the speaker wires from the amp in case the problem is in the amplifier (you don't want to damage the test speaker).
10/16/2007 10:23:36 PM • Bazooka... • Answered on Oct 16, 2007
0answers
Bt8250d is cutting out
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
11/30/2014 4:34:44 PM • Bazooka Car... • Answered on Nov 30, 2014
0answers
0answers
0answers
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
12/22/2009 9:19:21 PM • Bazooka Car... • Answered on Dec 22, 2009
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
6/15/2008 6:52:48 PM • Bazooka Car... • Answered on Jun 15, 2008
2answers
I need to know the security code of my 2009 Ford
SANYO Car Radio Codes Online:https://www.carstereocode.com/unlock.php?mk=66
11/24/2022 3:34:32 PM • Car Audio &... • Answered 2 days ago
27answers
Change language to English On NDDN w56 car DVD
i chane NDDA w56 languageto english
11/19/2022 7:12:40 AM • Car Audio &... • Answered on Nov 19, 2022
ROHL Aqui Two Handle Widespread Bathroom Sink Faucet
Look on the back of the handle with a mirror and you should see a recessed Allen screw. Some have a decorative can on top marked H & C, or red and blue. Those pop off. No info online, but this unit comes under many names, I answered one today already, low quality, high price and probably made in China or korea. https://www.google.com/search?q=ROHL+Acqui+Two+Handle+Widespread+Bathroom+Faucet+tighten+handle ..
11/12/2022 5:48:42 AM • Car Audio &... • Answered on Nov 12, 2022
2answers
BOSS Audio BV9976B In-Dash Single DIN DVD Player and 7 inch Motorized Touchscreen Monitor. Slide in a DVD/CD. Why can't I Bluetooth videos on my BV9976B?
Question edited to add 'FULL 'make model (what it is). There is a crucial word missing between 'I' and 'Bluetooth'. That verb is the key to answering the question. Bluetooth is only for calls, you can't stream videos if that is what you are trying to do? Here is the manual. https://www.google.com/search?q=boss+bv9976b+manual+bluetooth ..
11/10/2022 9:45:49 PM • Car Audio &... • Answered on Nov 10, 2022
Bazooka (EL10190PP) Car Audio Amplifier Logo
Popular Tags
4 questions posted
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bazooka Car Audio & Video
Most Popular Question
ela 500
  • Car Audio & Video
