20 Most Recent Aastra Telecom Aastra 57i CT Questions & Answers
Try 22222
Aastra Telecom... | Answered on Feb 06, 2015
set it to the value of the open SIP port of your phone system (5060?).
try out hitting * and # when restart phone for hard reset, or 4 and 6 for factory reset.
Aastra Telecom... | Answered on Feb 15, 2011
A hard reset is simply remove power and re-connect. If this fails, check the network connections by logging onto the web interface, you can find the IP address from the settings menu.
ip phone require a few things.
  1. power
  2. internet connection
since you posted here it would seem you have both of these. contacting your provider to see if there is an outage or a problem with service would be best.
Aastra Telecom... | Answered on Apr 25, 2014
Look at its function, then how to remove it if you still want to:
https://www.google.com/search?client=firefox-b-1-d&q=trayapp
Computers &... | Answered 10 minutes ago
100,000
+ 87
_______
100,087
Computers &... | Answered 19 minutes ago
If you're referring to the dongle used with a wireless mouse or keyboard, I believe you have to buy a new setup. The same would apply with a wireless adapter.
Computers &... | Answered 21 minutes ago
The graphics card supplying the signal could be bad, a pin could have been bent over when you plugged in the vga cord (if a vga display).
If a pin is bent, be careful bending it back; it can break off easily. Grab with needle-nose pliers or tweezers, and slowly bend. Don't over-bend.
Computers &... | Answered 25 minutes ago
I would:
  • try checking all connections, especially the power cord to the back of the monitor.
  • try a different monitor as a test to see if the monitor is bad or the graphics card supplying the signal.
  • Once you've narrowed down the cause you'll know what to replace.
Sorry, I don't have any cure for a bad monitor.
Computers &... | Answered 49 minutes ago
you can not back up dvd's
Computers &... | Answered 2 hours ago
Tip
Graphic Rendering The Real World
The real world is filled with complex objects: curves, textures, shadows, and especially the commonplace flaws found in everyday structures that make them real. The challenge for game developers is to duplicate these objects in a realistic manner. A character's face shouldn't look perfect, because there are always small blemishes, wrinkles, and other imperfections. Also, the physics of movement and interaction between objects in the real world have to be faithfully duplicated.
So the challenge for video card manufacturers is to create hardware that is able to support all of the programmatic techniques developed to present a realistically rendered world within a computer. When comparing video cards, you'll often run into terms such as bump mapping, anisotropic filtering, bilinear filtering, MIP mapping, etc. All of these (and others) are techniques implemented in the hardware that let game developers create realistic objects in their games. Let's take a very quick tour of what some of these terms mean.
GPU – Graphics Processing Unit; as video cards become increasingly complex, it pays to offload a lot of the heavy-duty visual processing from the computer's main CPU to what amounts to a mini-CPU on the video card. The video card's GPU does a lot of the computational heavy lifting required to render 3D graphics.
DDR – The term DDR is often used to describe a video card's memory. DDR stands for "double-data rate" and is a type of SDRAM used in video cards today. Double-data rate means this type of memory is able to move data on both the falling and rising edges of the clock cycle. DDR1 SDRAM is the most common memory in use with video card technology today and is able to move data in 2-bit chunks.
Again, the purpose here is to offload graphics rendering tasks out of the computer's main memory and CPU, hence the idea to equip video cards with loads of memory. Nowadays, a cutting-edge video card should pack 256MB of DDR1 or DDR2 SDRAM. Unlike DDR1, DDR2 memory moves data in 4-bit chunks, so data transfer performance is doubled. The newest video cards on the market today are beginning to adopt DDR2 memory.
RAMDAC – Your computer only understands digital, and your eyes can only see in analog. The video card RAMDAC's job is to bridge the gap between the digital and analog worlds and let the computer display analog images on the monitor. Faster RAMDACs (RAMDAC speeds are measured in megahertz) enable the computer to display higher resolutions on a monitor without annoying flicker.
3D Terminology – Today's video cards render highly realistic 3D images. To do this, video cards must faithfully reproduce what gamers see in the real world, including lifelike textures and realistic movements. There are a number of techniques implemented in both hardware and software that let video cards generate realistic 3D images. Let's take a look at a few of the most important:
Z-buffering – A technique implemented in the video card's memory that is used to store information about pixel location as fluid scenes are rendered. For example, if a pixel moves behind another, that information is stored in the Z-buffer.
Texel – Stands for "texture element." A texel is a graphics unit similar to a pixel, except it is used to define 3D graphics. Think of a texel as the base unit that defines 3D graphics.
Fogging – Technique used to simulate haze, fog, or smoke.
Trilinear filtering – Video cards use texture maps to apply textures, such as skin, surfaces, etc., to simplified models of objects called primitives. Essentially, these primitives are "colored" with textures stored in 2D images called texture maps. Textures must not only look realistic, they must also be adjusted, if need be, according to the position and movement of the object. Trilinear filtering is used to make this mapping appear more realistic.
Full-screen anti-aliasing – Anti-aliasing is used to smooth out transitions between pixels with different colors and reduce image "jaggies." This technique minimizes the jaggies at all resolutions.
Programmable vertex and pixel shading – These techniques allow the rendering of realistic lighting and shadow effects. For example, ATI's SMARTSHADER technology allows the implementation of DirectX 9 floating-point programmable vertex and pixel shading. NVIDIA's version is called CineFX.
DirectX 10 – This is Microsoft's latest version of the DirectX APIs that let video developers programmatically exploit the capabilities of existing video hardware. The API lets software developers quickly create games without having to know the intimate details of each
4 hours ago | Computers & Internet
sorry no idea what you are asking here
Computers &... | Answered 5 hours ago
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
For which model u need boot options
Computers &... | Answered 10 hours ago
Aastra Telecom Aastra 57i CT Logo
12 questions posted
Top Aastra Telecom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Aastra Telecom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Aastra Telecom Computers & Internet
Most Popular Question
sip register port
  • Computers & Internet
