20 Most Recent Sony Ericsson HBH-PV705 Headset Questions & Answers
My power button. Is not working and if keep for charging from red light itt changes into green but when I remove the charger pin no light indicates
Sony Ericsson... | Answered on May 18, 2018
I am having the exact same problem with my PV705! I've followed all the directions and tried charging it numerous times but still nothing.
Sony Ericsson... | Answered on Sep 18, 2011
There's no driver but there's no need for a driver. Go to the first link below and you'll find whateve you need to know about your device. If you can't find it you can contact them with any questios with the second link below. <br>
http://www.sonyericsson.com/cws/support/accessories/hbh-pv705styleedition?cc=us&lc=en
<br>
http://www.sonyericsson.com/cws/common/contact?cc=us&lc=en
Sony Ericsson... | Answered on Feb 02, 2011
To turn this headset on you simply press and hold the Call Handling Button for 5 seconds. If it turns on it will make a beeping tone and flash green.
Sony Ericsson... | Answered on Jan 26, 2011
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Sony Ericsson... | Answered on Jan 06, 2011
run microsoft updates on your computer 1. control panel 2. system and secruity 3. windows updates f that doesnt work to the manufators website and download the date drivers hope this helps
Yep. Buy it here from a danish webshop: http://www.gooby.dk/ write 8829 in the search area (you can put Google translation to english on, page is on Danish) Best Regards Henrik from Denmark ps. and if you buy a minimum of 2, you can have 50% discount by using THIS code 96f7f8ff - use it in the payment area... :-)
Sony Ericsson... | Answered on Nov 21, 2010
Press and hold down the headset volume key in the centre. Hold it for about 5 sec. The led will now flash on/off in red. This is the pairing mode. Set your mobile phone to blue tooth discovery mode,until it finds the headset, key in the pass key, 0000. It should now work. You may need to set the phone to select the headset as an automatic connection so it connects whenever it is on and in range.
Sony Ericsson... | Answered on Nov 16, 2010
You should press both + and - button on your head set and wait until green light turns into red.
Sony Ericsson... | Answered on Oct 09, 2009
failed to power on after initial charge
Sony Ericsson... | Answered on Sep 25, 2008
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Sony Ericsson... | Answered on Dec 02, 2017
Sony Ericsson HBH-PV705 Headset Logo
Popular Tags
31 questions posted
Top Sony Ericsson Radio Communications Experts
Anthony Ward
Anthony Ward
normis101
 Mike M
Mike M
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Radio Communications
Most Popular Question
need driverfor bluetooth
  • Radio Communications
