20 Most Recent Amana RanARG7302 Gas Kitchen Range Questions & Answers
You will need to replace the igniter on the broiler. Here is that part to order.
Amana RanARG7302... | Answered on Feb 18, 2013
No it will not...the surface burners can be lit w/a match but no oven when power off
Amana RanARG7302... | Answered on Aug 29, 2011
Yes. Lift up the whole top of range from front. It pops up an inch from top and tilts back. Remove grates first. Clean off unlit orfice with brillo pad and poke the hole with a pin. light it. Gently put top down or it will blow out the pilots.
Amana RanARG7302... | Answered on Jan 28, 2011
Looks like your range uses 2 different valves. The large burners use part #317227701 which is no longer available. Small burners use part #R0150174 which can be ordered from Marcone Appliance Parts. If your problem is with one of the large burner valves, you might be able to order one for the smaller burner valves and use the old orifice.
Amana RanARG7302... | Answered on Jan 13, 2011
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Amana RanARG7302... | Answered on Jan 09, 2011
heatman101
Amana RanARG7302... | Answered on Nov 27, 2010
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Amana RanARG7302... | Answered on Nov 16, 2010
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Amana RanARG7302... | Answered on Sep 21, 2010
Amana RanARG7302 Gas Kitchen Range Logo
Popular Tags
80 questions posted
Top Amana Kitchen Ranges Experts
Paul Carew
Michael Thomas
Michael Thomas
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Kitchen Ranges
Most Popular Question
oven glow plug but gas oven not top
  • Kitchen Ranges
