20 Most Recent Acer Aspire T135 PC Desktop Questions & Answers
your using outdated windows systems that are no longer supported by any software vendor.
that's why they won't install or work correctly..
I use win 8.1. its the beas windows ever written.
I've used all windows over the last 22 years
Acer Aspire T135... | Answered on Aug 01, 2017
U may have to follow the following steps to detect the exact problem
1) Check the power cable convectivty from UPS to SMPS box
if this is OK then check the Fan of SMPS box and POWER LED of the cabinet, if Fan runs, and power LED lights, then u might have to check the Display. If display is not there then it might be the RAM problem
2) if u find all the proper cable conncectivity, then u need check the LED on mother board. but take this step if it is assemble system or if u have hardware knoledge or else contat the system vendor
Acer Aspire T135... | Answered on Oct 11, 2016
Run your PC in safe mode with networking prompt as an administrator(because in normal mode the virus will not allow/let you to run a setup file if it's a dangerous virus).Install strong anti-virus like Kaspersky, NOD32 etc. registered version. Update the anti-virus in safe mode and also run.
I think it will help you.
Good Luck
Acer Aspire T135... | Answered on Jun 28, 2016
Hi! Your problem is in your computers memory, replace your the computers memory. good luck,thanks
Acer Aspire T135... | Answered on Nov 15, 2014
It happened to me: the hard-drive was no longer working. You need to replace it.
Acer Aspire T135... | Answered on Nov 18, 2013
My wife's laptop did that too, she took it too a technician and they needed to replace the hard drive. But maybe yours could be different. Just take it to someone that can fix it.
Acer Aspire T135... | Answered on Oct 24, 2013
check your processor,Ram first
or board problem
Acer Aspire T135... | Answered on Oct 17, 2013
You can put cooling fans on anything. It looks like you can put a fan on the back, its looks to be a 80 or 92mm fan. I recommend a dual ball bearing fan if you go that route since they last longer. You can also put one on the side, if you cut a hole for one on the side. Another good option would be to upgrade the cooling for the processor with something that is all copper, and use artic silver 5 as the thermal paste.
Acer Aspire T135... | Answered on Sep 14, 2013
Are all the vents clear from obstructions, fluff etc?
Acer Aspire T135... | Answered on Aug 06, 2013
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentialsonce you have your computer running or you could do this in safe mode
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
Scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might still have a virus
If you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
Click start control panel administrative tools computer management disk management right Click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
You should always ask for a guarantee on compatability before purchasing any ram and buy working pairs if possible.
you might have to many programs running at the same time putting to much strain on the CPU
Try uninstalling a few unnecessary programs.
this should speed up your computer
or you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Acer Aspire T135... | Answered on Jul 14, 2013
yep - there is no maximum HDD size for computers just as long as you have the right connection (Sata or IDE) then you can fit any size you like.
Enjoy :D
Acer Aspire T135... | Answered on Jun 20, 2013
That is typically a "memory address error".
Save all "My Documents" to an external hard drive.
Reload Windows.
If the error persists after doing Windows Update. you may have generic memory causing the problem.
go to www.crucial.com for memory upgrades.
Acer Aspire T135... | Answered on Feb 16, 2013
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Acer Aspire T135... | Answered on Dec 20, 2012
Viewing FRONT of computer the LEFT Side panel removes.
Viewing REAR of computer there are two Thumbscrews to loosen.
One towards the Top, one towards the Bottom.
(Not supposed to come all the way out, but OK if they do)
There is a 'bulge', or 'bump' formed at the back of the Side Panel.
This is a fingerpull handle.
Pull back on the Side Panel towards the Rear of the computer.
The Side Panel will only slide so far. This is because there are metal L-shaped tabs formed out of the Side Panel, that go into slots in the metal framework, of the computer case.
The L-shaped tabs are like a hook. You may have to ease the Side Panel a little forward, then the L-shaped tabs will clear the slots, and the Side Panel can be brought out to the side, and removed.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your unplugged from power, computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, if the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
May I ask what the problem is, or is this for a simple upgrade?
For additional questions please post in a Comment.
Regards,
joecoolvette
Acer Aspire T135... | Answered on Nov 07, 2012
Mechanical or electronical drawer?
Is the button stuck?
Acer Aspire T135... | Answered on Oct 25, 2012
Acer Aspire T135 PC Desktop Logo
128 questions posted
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire will sometimes refuse start
  • Computers & Internet
