20 Most Recent Amana ACS3350AS Gas Kitchen Range Questions & Answers
Oven shuts off; display blinking
If you're inclined to fix this yourself and can't find a replacement control board (no doubt that's what you need), try www.fixyourboard.com They will repair your board and return it to you with a 1 year warranty.
5/6/2017 1:59:51 AM • Amana ACS3350AS... • Answered on May 06, 2017
Oven lights but does not get hot enough
My oven lights, but takes for ever to heat or will not heat at all. Anyone know how to trouble shoot the issue?
11/23/2014 11:30:55 PM • Amana ACS3350AS... • Answered on Nov 23, 2014
How to regulate flame on a gas oven stove
On a gas stove, you simply choose the desired temperature. If the stove is operating normally, it will automatically adjust the flame.
8/5/2014 5:31:07 AM • Amana ACS3350AS... • Answered on Aug 05, 2014
Kitchenaid kgsk901sss02 disply don't work oven don't turn on but burner work fine
You need to replace the control board. Here is that part to order. Whirlpool 9762793 Cntrl Elec AppliancePartsPros com
5/1/2014 2:13:48 AM • Amana ACS3350AS... • Answered on May 01, 2014
Heat escaping through the top of the range, making the stove extremely hot, and keeping the oven from getting up to temp
Gas stoves vent direct to back of cooktop. They do get really really hot. you can warm food for free while baking. Check your broil and bake elements are both running.http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Range-Parts/Model-ACS3350ASPACS3350AS0/1268/0124250/M0312601/00003
11/15/2013 5:27:01 PM • Amana ACS3350AS... • Answered on Nov 15, 2013
Code f9 appears display shows "locked'
Google Amana error code F 9. Looks like a door lock situation which sometimes occur after self cleaning.Get that info on meaning of F 9 so more people can help you. Or there might be someone with his error code book at the ready.Good luck.
10/21/2013 2:57:27 AM • Amana ACS3350AS... • Answered on Oct 21, 2013
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
11/27/2011 1:29:43 AM • Amana ACS3350AS... • Answered on Nov 27, 2011
Gas oven will not turn on. Everything else works.
Hello Richard,Do you see the ignitor glowing in the oven yet no flame to the burner??If yes ya see the ignitor..while it seems strange the ignitor is the problem and its not getting hot enough to allow the gas to flow to the burner...by replacing the ignitor it will repair the oven.Let me know it the ignitor does not seem to be glowing and i will tell ay how to check it since by far its very likely the problem.GENE
11/7/2011 9:51:40 PM • Amana ACS3350AS... • Answered on Nov 07, 2011
I have an amana acs 3350 that keeps shutting off
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance. Daniel
10/1/2011 5:50:44 PM • Amana ACS3350AS... • Answered on Oct 01, 2011
The heating element goes on but the oven does not
Hello, dinophyl (early Jurassic protozoa, hey) Do you have a Gas or Electric kitchen range? Very good possibly that the thermostat control in the oven is bad. That little brass bulb in the oven. This controls the internal temperature of the oven. If it an electric range then the the electrical thermostat on the oven knob could also be the culprit also. GB..stewbison
9/24/2011 4:37:52 PM • Amana ACS3350AS... • Answered on Sep 24, 2011
Fault code F-3 displayed
Hi paulkowalews,
The F3 fault code description is an open or shorted oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
9/23/2011 7:53:17 AM • Amana ACS3350AS... • Answered on Sep 23, 2011
Amana ACS3350AS Gas Kitchen Range Logo
90 questions posted
Top Amana Kitchen Ranges Experts
Paul Carew
Mike
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Kitchen Ranges
Most Popular Question
kitchenaid kgsk901sss02 disply dont work
  • Kitchen Ranges
