20 Most Recent
Numark Fusion 494 Complete DJ Package Questions & Answers
Turntables manuals
Try looking on Numark's website. For more information, please visit my website at audioserviceclinic.com. Thank you.
Where can I find a
The truth is that the user manual for your Numark Fusion 494 DJ Package
is not available anywhere online.
The manufacturers of this unit did not make it available. I went
further searching and couldn't find any.
I would suggest you
contact the manufacturer of this unit via phone or e-mail and
request for the user manual from them. They might give it to you or direct
you to a dealer where you can get the user manual.
This is the best you can do to get the user manual you are requesting for.
Go to the Numark Fusion's website, check "Contact Us" and you would see
their e-mail and phone number.
Good luck.
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
TWEAK AV LAB
My numark 5000fx lights up when turned on but does not register my technics on any of the channels
If your Numark 5000FX mixer is not registering your Technics turntable on any of the channels, there are a few things you can try:
- Check your cables: Make sure that your RCA cables are plugged in correctly and securely. If you are using a phono preamp, make sure that it is powered on and connected properly.
- Check your switch settings: Make sure that the switches on the back of the mixer are set correctly for the type of input you are using (line or phono).
- Check your levels: Make sure that the input levels are turned up and that the fader for the channel you are using is not muted or turned all the way down.
- Check your ground wire: If you are using a turntable, make sure that the ground wire is connected properly to the mixer.
If none of these steps work, there may be an issue with either the turntable or the mixer. Try testing the turntable on a different mixer or testing a different turntable on the Numark mixer to determine which component is causing the issue. If the mixer is the issue, it may need to be repaired or replaced.
Ok i just purchased my idj3 and installed all the
Make sure you install the software in the CD provided with the iDJ3. IF you already have, try to uninstall, restart and then reinstall. Sounds like the drivers for your device was not properly loaded to your PC which cause it not to recognize. If it still doesn't work after that, I suggest that you contact Numark tech support for further troubleshooting at this link:
http://www.numark.com/content54
Good luck and vote this solution if it helped you. Cheers
