20 Most Recent
Western Digital 250GB My Book Pro-External 250 GB Hard Drive Questions & Answers
My external hard drive icon does not appear on my
Try the drive on a windows machine and a Linux machine. It depends on the drive has been formatted. If ex fat or fat then it should be read on a mac ok. If NTFS or Fat 32 then a windows machine should see it.
My external hard drive is not working. It makes a
If it still is under warranty, exercise the warranty, and get a replacement.
If the warranty has expired, disassemble the case, and extract the disk-drive. Connect that disk-drive as a "slave" disk-drive in some desktop computer, and see if the disk-drive is still functioning, and if the files on the disk-drive are still readable.
I ;have formatted the WD external drive and
You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
Sir,
I have a Lenovo laptop.
If your HARD DRIVE was exposed to a magnetic field, this can happen.
Try a scandisck run.
Boot up in safe mode and run fix disk.
Cannot format my WD 1TB external hard drive
The hard disk is having bad sectors on its first 3000 sectors.the bad sectors are caused by degradation of the platter of the hard disk.OR the factory area of the hard disk has certain files called SMART, G -LIST and other log files.Unless one empties those log files with a good tool , one cant format ones hard disk.
Not detecting, beeping
This is likely a couple problems;
1. The hard drive is dying or is dead. You're looking at hardware recovery if this is the case. There are some tools such as Spinrite that might be able to recover the disk. (
GRCHard drive data recovery software)
2. The power supply on the computer/laptop is not functioning as well as it used to. Try using another PC to see if there's any difference in results.
Western digital 2tb my passport keeps flashing; not detected
Remove the drive from the external case it is in and connect directly to your computer - see if the bios recognizes it. If so, the OS will do so also and you can access it. Also means the electronics of the external case are no good. If not recognized in other machine, the hard drive has gone to hard drive heaven and needs to be replaced.
