20 Most Recent Stabila 05000 Self-Leveling Rotating Laser - Type LAPR-100 Questions & Answers
ask fluke i never had any errors on mine
Measuring Tools... • Answered on May 07, 2021
It's telling you that it is a Fluke 177...ie the (F177). Absolutely normal.
Measuring Tools... • Answered on May 06, 2021
I've got one of these. No idea how to change the date
Measuring Tools... • Answered on Apr 15, 2021
First of all, this is a problem the guys from Home Depot wouldn't know how to fix.
Years ago, maybe when this post was originally written you may have needed to do a two coat system.
Your best and actually easiest option will be to power wash your stucco, to remove any dirt from the surface.
Then you will need to mask everything up tight because you're about to spray all the stucco. Cover any concrete and plants nearby, (anything that is closer than 10 feet from the stucco.)
Then go to Sherwin-Williams and purchase Loxon XP this is a one coat system however if you have larger cracks in the stucco you will either want to caulk them with an elastomeric caulk (if you don't have too many) or apply a second coat of Loxon XP. If you're a do it yourself kinda of person you can go to home depot and rent a spray machine. While your spraying your gonna want to back roll it. www.outbackpaintingusa.com
Measuring Tools... • Answered on Mar 12, 2021
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Measuring Tools... • Answered on Mar 06, 2021
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Measuring Tools... • Answered on Feb 24, 2021
Page 6 of the manual refers
DIGITECH XC-0366 USER MANUAL Pdf Download ...
www.manualslib.com > ... > Weather Station
Temperature Alert Setting: You can program your weather station to sound an alert whenever the outdoor temperature exceeds the upper or lower pre-set limit.
Measuring Tools... • Answered on Feb 09, 2021
I had the exact same problem and after messing around with it for about half an hour I realized that the cord was the problem, I was kind of moving it around while plugged in and if I hold the end of the cord in a certain direction it works like it should. If the results are the same for you, I suggest either getting a replacement cord or just do the not so reliable option and tape the cord into place.
Measuring Tools... • Answered on Jan 17, 2021
It is a known issue Try first a general reset: - remove the batteries from the clock (thus turning it Off.) - remove the batteries from the outside sensor (if you are not aware that it has batteries, then perhaps it is not working because the batteries are no good any more! check that also.) - wait 10 minutes with no power to the device. - put batteries back in, power On again. - hit Reset. - hit Receive button. - change the channel for reception from the outside sensor. - change the channel on the outside sensor to match that channel. - then set the time once more, once the remote temperature is sensed once again. If this does not get the outside temperature reading working again, you may have to replace that temperature sensor. https://www.google.com/search?q=Model+spc373 ..
Measuring Tools... • Answered on Jan 02, 2021
It is a wired system (outside unit to the indoor phone) and only available in South Africa. This seems to be the distributor and there is no manual online. The are far better systems with colour video, audio and wifi or bluetooth. https://www.game.co.za/game-za/en/All-Game-Categories/DIY-%26-Auto/Home-Security/Intercoms-%26-Alarms/Alarms-%26-Sensors/Digitech-Wired-Door-Phone-BPSDP3206A/p/504101-EA ..
Measuring Tools... • Answered on Dec 30, 2020
Try removing all batteries, then reinstalling in the outdoor unit and waiting for it to start sending data before reinstalling batteries in the indoor unit. If you don't see data displayed on the indoor unit, the outdoor unit may have failed.
Measuring Tools... • Answered on Dec 24, 2020
Stabila 05000 Self-Leveling Rotating Laser - Type LAPR-100 Logo
Popular Tags
2 questions posted
Top Stabila Measuring Tools & Sensors Experts
Bill Boyd
Tom Chichester
Are you a Stabila Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Stabila Measuring Tools & Sensors
Most Popular Question
stabila lapr 100
  • Measuring Tools & Sensors
