20 Most Recent
ASUS P5VD2-X Motherboard Questions & Answers
How to boot from cd on asus p5vd ?
To boot from cd you have to make sure that 1 - the disk is bootable and 2 - you must make sure that your CMOS is set to boot from the cd rom first before anything else.
If your cmos is not responsive to the changes that you want when you click on exit and save it is either because you are attempting to change something that is not changeable or the cmos is corrupt and not working properly.
P5VD2-X
the heatsink maybe wrong for the cpu?
W7 64 bit pro
These are the specs, but I don't see 64 Bits support. Hence it must be running 32 bit and Windows 32 Bit has a 3GB limitation. Furthermore, even if it did recognize it. Your applications must be written to utilize more RAM. For instance I have 16GB and never seen the usage go more 3GB.
http://www.asus.com/Motherboards/P5VD2X/#specifications2 x DIMM, Max. 4 GB, DDR2 533/ Non-ECC,Un-buffered Memory
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
I don't what kind vga
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Muh Adhitya.Your ASUS mainboard uses a PCI-e 16X which means PCI-Express graphics card slot.Meaning that you will be able to install most PCI-Express graphics cards from any manufacturer. AMD/ATI or Nvidia.Take care!Norman-Wynne Damstra
P5vd2 not sound on win
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Rifaguant.Try the Vista drivers, Click
here to download the Audio driver.Select your Operating system as Windows Vista 32bit.Click Audio heading and then click global to download, you may have to try both drivers if the first one doesn't work.If they both don't work then:ASUS has not created Windows 7 drivers for the Audio chipset on this mainboard. You will need to purchase a basic sound card to fit the White long PCI slot compatible with Windows 7.Try eBay or your local computer store.Take care!Norman-Wynne Damstra
I just upgrade my processor
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Tim.I think that you will need to upgrade the BIOS software for your mainboard.This will increase support you new processors, it would be best for a computer technician to flash the BIOS for you.Click
here to download the latest BIOS for your ASUS mainboard.Click the BIOS heading and then click the latest one being the top one. Click Global to download.Take care!Norman-Wynne Damstra
Driver audio p5vd2-x bioos301
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Hira Printin.Click
here to download the drivers for your ASUS mainboard.Select your operating system and then click the heading Audio.Now click global. Once installed you will need to install it.Take care!Norman-Wynne Damstra
ASUS P5VD2-X vga
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Ichigo.Since your ASUS mainboard has no onboard VGA graphics adaptor you will need to install the Video/Graphics driver for your Installed Graphics Card.Find the make and model number of this card and then either place it as a comment to this solution or visit the appropriate manufactures website:For Geforce graphics: www.nvidia.comorFor ATI/AMD graphics:
www.amd.comThe make and model number can be found on the graphics card. Usually printed on a sticker.Take care!Norman-Wynne Damstra
ASUS P5VD2-X Motherboard Driver download
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya, Ichigo.Click
here to download the drivers for your ASUS mainboard.You will need to select your operating system and then click on each heading for the drivers. Download via the global.Take care!Norman-Wynne Damstra
Is compatible with innod3d GT-210
Welcome to FIXYa!
Yes, it is compatible, you motherboard has PCI Express expansion slot, therefore, it should work.
Your videocard specifications are as follows:
-Intel Pentium 4/III/II/Celeron / dual Core, AMD K6 / Duron / Athlon /
Athlon XP or equivalent.
-A minimum 350W
system power supply.
-A PCI Express or
PCI-E 2.0 compliant motherboard with full-height free slot. -50MB of available
hard disk space.
-CD-ROM or DVD-ROM
drive to load the driver or download at NVIDIA.com. -VGA adapter or
DVI-I compatible monitor.-Support for
Windows 2000/XP/Vista/Windows 7 or above system. You can also check your motherboard specs by clicking on this link: http://reviews.cnet.com/motherboards/asus-p5vd2-x-motherboard/1707-3049_7-32309682.html Hope this helps.
I have been getting too
if you get it during boot then at least a critical file of Windows itself is corrupted or missing. Reinstall, there's nothing else left to do.
My asus p5vd2-x give the
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Mainboard Asus P5AD2-E drivers for
Sorry to said but there are no official drivers for your motherboard for Windows 7. Is suggest you to use prior drivers (get
WinXP or Vista from
this link), right click on the installation file, click on
compatibility tab, choose compatibility with the version you download and click apply - ok. After this install with the normal way.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
No disply p5vd2-x
If there is no display, then follow this steps to troubleshoot it,
As it been displaying before and suddenly stops displaying, if your answer is yes then start with
1 check whether there is power to the board i.e power gets to the motherboard
2 Check the cmos battery,whether it is still ok, you can find the cmos battery on the motherboard
3 Check the RAM or memory whether it is firmly connected to its slot and working good
4Check whether your VGA chip on the motherboard is good if not you have to get an external VGA card and plug it on one of the slot either PCI or AGP slot.
5Check the data cable to the monitor, if it is still good,by removing it and testing it a good one.
6Check if the problem is not with your monitor either CRT or LCD by testing with a good one.
If the motherboard is a new one and is not displaying , i would recommend you return it and collec a new one
regards
