20 Most Recent SimpleTech SimpleDrive 250 GB External USB 2.0 Hard Drive Questions & Answers
2answers
I have a simpletech 250 GB external hard drive
May seem like a silly question you are not booting up computer with ext drive still plugged in are you? i am assuming your operating system is on the internal drive. if so don't have the external plugged in when you start up.
12/9/2017 8:01:10 PM • SimpleTech... • Answered on Dec 09, 2017
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
12/18/2015 12:44:45 AM • SimpleTech... • Answered on Dec 18, 2015
Have several Simpletech 250 GB drives. All are
Hi You don't say how all these devices are connected at any one moment in time, whether you use a USB hub to plug multiple devices in simultaneously or whether your otherwise detailed and very good description of the background to the fault applies even when nothing else but the problematic drive is plugged into the laptop, or whether you use the same or different USB cables with the different drives and the different computers. It's worth eliminating a USB Port fault or a USB Hub overload or a USB cable fault as the potential causes of the problem, if you have not already done so. USB is a relatively limited technology in Data Transfer Speed terms and is susceptible to Data bottleneck problems leading to read/write errors in external drives. The Simple Tech case contains a controller card. The Simple Tech controller card may be faulty or failing due to an accumulation of such read/write errors and is probably not communicating well with the Lenovo's Operating System. Because of Temporary Files and Error Reports created whenever a read/write errors occur, The Lenovo 'remembers' the problematic drives electronic signature from the last connection and also remembers its response and therefore defaults back to the same reaction most times you connect the drive in question. The drive has no 'history' with the Dell, so no problems arise when it's connected there. The other drives might be mechanically identical, but the internal controller board of each has a different electronic signature. The controller card has a chip on it that contains information in it that identifies what type of device it is to your operating system and then invites the Drivers for the device to start intermediating between the device and the operating system. Some error in the interface between that chip and the Lenovo is causing your problem. It is purposeless to continue using the problematic SimpleTech Enclosure with your Lenovo Laptop. You have already alighted on the best, simplest and most practical solution -re-house the problematic drive in a good quality, well ventilated new enclosure. The controller in the Eagle case also has no 'history' with the Lenovo, hence the clean response. For intellectual curiosity, you could swap the hard drives around in two of the Simple Tech cases to see what happens. Also there might be a Firmware update for the problematic SimpleTech Case that might flash and overwrite the Controller card main chip. I am unable to check this for you as I would need the Drive's part Number. This is the relevant site: http://www.hitachigst.com/support/index-files/simpletech-legacy-downloads
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most insightful, comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question. Thanks for using FixYa
9/7/2011 12:33:00 AM • SimpleTech... • Answered on Sep 07, 2011
When turn on my simpletech 250GB device its say
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps
12/31/2010 11:11:42 PM • SimpleTech... • Answered on Dec 31, 2010
Computer wont recognize hard drive and drive keeps
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered sucksion vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
hope this helps good luck
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
9/13/2010 8:03:30 PM • SimpleTech... • Answered on Sep 13, 2010
Simpledrive model 96300-40001-001 need software for Vista
Why do you not upgrade to windows 10 for free
6/4/2016 11:23:28 PM • SimpleTech... • Answered on Jun 04, 2016
Hi, I'm trying to do a backup of my photos, documents and music, but am unable to locate those itmes on the C Drive.Any suggestions?
you can use the windows search option to be able to find those files, but that will take a long time. you can use a backup drive or a backup software, they are almost reliable. if the files are important, then i would recommend taking a backup with the help of a technician. Call 1-877-805-1027 for toll free expert help.
10/25/2015 3:37:48 PM • SimpleTech... • Answered on Oct 25, 2015
My external drive will not open on my new HP computer
Unplug the external. Then Try rebooting cold. When the computer stops +30 sec. Reboot the computer and plug the external when you see the HP splash screen.
  • If that does not work, make sure you have the drivers for the ext. for your configuration. Win 8, 8.1?
  • You can go to the site where your external was developed at and make sure you have latest drivers and if there is a problem associated with your device.
  • On newer machines there is also 3.0 USB connections. While it should not make any major difference, make sure that your ext. is not plugged into a 3.0 USB. The 3.0 USB is blue in color.
1/18/2015 4:59:34 AM • SimpleTech... • Answered on Jan 18, 2015
The industrial revolution transformed old cities simple subject
You need to look on a site specifically for that historical information. Fixya is not designed for this kind of question.
1/18/2015 4:50:24 AM • SimpleTech... • Answered on Jan 18, 2015
Can SimpleTech runs on 220 voltage
Not enough info..... Ask Simpletech. I Dont use simple tech brand but it usually is similar to other products. Most Hard Drive Boxes are connected to a Power Pak that goes into the AC wall outlet to drop the power down to low DC voltage. Most power pak's handle 110 & 220 ac these days. Read the tiny writing on the power pak label. It's usually marked as input & output. Good Luck
11/1/2014 2:53:07 AM • SimpleTech... • Answered on Nov 01, 2014
2answers
Why would windows stop seeing my drive intermitently
Faulty cable, bent pins try another cable check pins if it is an old IDE.
9/15/2014 10:39:06 AM • SimpleTech... • Answered on Sep 15, 2014
Where can I get a device driver for windows 7 for
Windows 7 has a driver site. You need to go to your specific brand of computer/laptop and search drivers for it running with win 7. Here is a generic driver for win 7
7/18/2014 2:18:02 AM • SimpleTech... • Answered on Jul 18, 2014
0answers
SimpleTech SimpleDrive 250 GB External USB 2.0 Hard Drive Logo
7 questions posted
Top SimpleTech Computers & Internet Experts
Ekse
Joaquim Martins
Raj Patel
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Simpledrive SimpleTech
  • Simpledrive SimpleTech
Most Popular Question
simpletech 250 gb external hard drive
  • Computers & Internet
