20 Most Recent
Amana ARDS802 Electric Kitchen Range Questions & Answers
Downdraft
I would leave it alone, taking the oven door apart is a real pain in the rear.
When setting the oven temp, it always refaults
If the oven just wasn't heating up, I would say temp sensor is bad. If the panel is switching itself, then likely the control panel is bad. Partselect . com and daysappliance both have your parts, diagrams, manuals, and are really affordable
How/what can be used to clean range
Oven cleaner, use EASY-OFF Fume Free Oven Cleaner, it is the best
for cooked stains.
You should not use anything but a soft cloth, and if you use the cleaner
you won't need something abrasive.
Once you put tiny scratches into the glass, it will be more difficult to clean.
After you clean it with oven cleaner, rinse it with a warm wash cloth a few times, to make sure no cleaner is left behind, and read the directions.
We have an Amana ARDS802.
You might check the oven control on the inside to see if any wiring, clamps or washers may have busted off te knob/control. Since the exhaust fan and stove still work, I would say the problem is only in or near the oven control.
Amana range
Hi j grangeruth,
Happy to help you!
If it is 10 years older or more, I would not recommend investing a lot of money into repair!
I think that this problem will be solved only by service!
Try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
We recently moved, when we got to our new house we
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
