20 Most Recent
Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Questions & Answers
Is a HP Pavilion MCP73M01H1 (Napa) the same as a Foxconn M7PMX-S?
oh wow. Why would the lady say such an ignorant thing with such
conviction. This is just nonsense as we all know companies outsource
all the time, precisely Retail driven, close to the end user companies
like HP and Dell. PRODUCING is not the same as contracting out a set of
mobos like the gentlemen correctly suspected of being the same as a
foxconn model. I happen to have an HP with a foxconn mobo (and to the
guru lady, it seems to also have Nvidia's signature, so really, what
you see here, is Nvidia provides tech, Foxconn manpower and efficiency,
and HP sales and marketing and the product sells, but suggesting HP
which cant get to the phone to keep up support go out and actually
manufacture their own mobos is the stuff of laziness).
To the gentleman asking, I have looked at the specs and your analysis
seems to be right on. Here's another exact HP product (the one I own,
given another HP special foxconn mobo name given the sheer volume of
business these folks generate to foxconn. It does seem to get often
confusing though and if I were you, and you seem to be quite familiar
with hardware and the such, if you were to attempt a flash, make sure
to backup first, that is the only harm you will cause to your computer,
if you are not cautious even when you're certain. Here's the link to
which I mentioned so many times:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-71054-1&lc=en&dlc=en&cc=ca&lang=en&os=2093&product=3771694
1/23/2018 4:59:54 AM •
Intel...
Answered
on Jan 23, 2018
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
5/24/2016 12:18:56 PM •
Intel...
Answered
on May 24, 2016
Multymidia audo controller driver
go to intel download support at discon boards then type in your board then download them you may want to update your drivers as well
3/24/2014 5:45:16 AM •
Intel...
Answered
on Mar 24, 2014
Motherboard can't display CPU fan moving fast no beep ram is ok no power supply problem keyboard LED flashing CMOS battary is new but display isn't showing anything
"no beep"... if your motherboard (mobo) has a system beeper and there is no beep on boot, the BIOS is not recognizing the keyboard so the computer will not boot. Reset the BIOS back to factory default. Unplug the computer, remove the battery for 10 minutes. Put it back in and try to boot. NOTE: be sure not to reverse the battery polarity! Usually the + side is up, but check your computer manual booklet. There is a small jumper on the mobo that you move to one side and back to original position again, which clears the CMOS settings. If you don't know where it is, see your computer manual booklet. If you still can't find it, just go with the above instructions.
3/6/2014 2:00:07 PM •
Intel...
Answered
on Mar 06, 2014
No disoiy 945GC
go to web site of intel download support type in your board then download drivers and manual same time ok
11/11/2013 6:28:20 AM •
Intel...
Answered
on Nov 11, 2013
NEED INTEL CHENNAI SERVICE CENTRE ADDRESS?
Genune Chiplevel Service of Laptop And Desktop Mother Boards,Spares Contact: Multiware Info System, #163, North Usman Road, T.Nagar, Chennai-600017. CUstomer Support: 9841036469,9841602538,39.
5/31/2012 10:36:52 AM •
Intel...
Answered
on May 31, 2012
I have 2 DDR2 RAM
Hi ,
your computer is preset to handle so much memory , you need to find out how much it can handle ,you can do this by going online , and google your make and model of computer and read the specs on your computer .....................hope this helps ................good luck Roy ,
9/3/2011 8:43:40 PM •
Intel...
Answered
on Sep 03, 2011
Intel 945 mother board no
501, 5th Floor 4 Venkatanarayana Road Chennai
Chennai FSO Kuppu
501, 5th Floor
Chennai, Tamil Nadu 600017
India
Redington (India) Ltd. SPL Guindy House 95, Mount Road, Guindy Chennai 600 032, India. ... Phone: +604-659 9679. Fax: +604-658 9607, CPU - Boxed, Tray, Mobile; Server ...
hope this will help you
6/18/2011 5:18:26 AM •
Intel...
Answered
on Jun 18, 2011
My computer is not starting
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
5/30/2011 4:42:04 AM •
Intel...
Answered
on May 30, 2011
945gc his v3.0 Express Chipset Family drivers
i have lost sound after i have formatted my pc and installed WinXP, my PC is 945GC (HIS) v3.0 mother board core2duo. plz sugget the appropriate sound card driver for this
2/9/2011 10:08:05 AM •
Intel...
Answered
on Feb 09, 2011
