20 Most Recent ASUS P5LD2 Motherboard Questions & Answers
Error Can not find graphics card information
its intel 945 display you can download it from intel.com
4/6/2017 4:14:12 PM • ASUS P5LD2... • Answered on Apr 06, 2017
2answers
Help find driver
hi! download you motherboard driver from here!
www.nodevice.com/driver/P5LD2-VM/get34084.html - 15k
drivers.softpedia.com/get/BIOS/Asus/Asus-P5LD2.shtml - 55k -
www.driverfiles.net/Bios/ASUS/P5LD2/download/page,sh,30052,172,6,.html - 60k -
10/30/2015 9:22:10 AM • ASUS P5LD2... • Answered on Oct 30, 2015
manual
0answers
Bios update
Be the first to answer 4/30/2013 12:08:05 PM • ASUS P5LD2... • Posted on Apr 30, 2013Be the first to answer
3answers
Cmos checksum bad...usb current status detected system shut down 15 sec
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
3/16/2013 11:23:32 AM • ASUS P5LD2... • Answered on Mar 16, 2013
P5ld2dual core onboard lan disabled but wont boot
This is either a driver problem or a "hard" hardware problem. When you are in safe mode you should remove the drivers for the onboard lan and the wireless USB. the most likely cause is the wireless stick. So try re installing the usb drivers again from a different source.
7/19/2012 8:31:55 PM • ASUS P5LD2... • Answered on Jul 19, 2012
The 3.3 volt is zero in asus 945
check the voltage in the mosfet if there is voltge check the mosfet for leakage if leakage remove the mosfet with new one
2/15/2012 8:17:41 AM • ASUS P5LD2... • Answered on Feb 15, 2012
0answers
2answers
Ethernet drivers looking P5LD2
I am not sure if the motherboard has been certified for Win7.
However the Vista LAN drivers are available from this site.
9/15/2011 1:08:52 PM • ASUS P5LD2... • Answered on Sep 15, 2011
3answers
I cant install my Asus p5ld2 se driver in windows
Your windows version is trial or genuine, u check. Or u open your net & register.
9/15/2011 12:55:44 PM • ASUS P5LD2... • Answered on Sep 15, 2011
Where can i buy a
http://www.ebay.com/sch/i.html?_nkw=asus+p5ld2+motherboard
9/10/2011 2:46:02 PM • ASUS P5LD2... • Answered on Sep 10, 2011
Driver sound
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html http://download.cnet.com/soundmax-integrated-digital-hd/3000-2110_4-207821.html if these arent right you will find free sound drivers http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for ie:intel laptop (be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope it helps you
8/26/2011 9:14:30 PM • ASUS P5LD2... • Answered on Aug 26, 2011
Hi How to fix.....? No picture
First, see what led up to the picture not appearing.
Did the computer suddenly go off, or was it playing up for a while beforehand?
I have this board and it has generally been trouble free, although from time to time it will not show a picture and needs rebooting.
If you can, try this on a different monitor to see if the monitor is at fault first
  • Check that you are getting power to the board. That the PSU is switched on and is giving the green led light.
  • Next, do the fans on the board spin up? Is the CPU fan working?
  • Is there a light on the power button and is there a light on the board led?
  • Is the graphics card (if fitted) tight in the slot and if you are using the onboard graphics, is the VGA lead firmly connected?
  • Can you boot into safe mode (F8)? Or is this a problem even if that is tried?
  • Physically inspect the motherboard, can you see any signs of blowing or bulging capacitors, or any other burned components?
  • Next check the RAM, remove and replace one stick at a time.
  • Did you install any windows updates recently? Or updates to the graphics driver? If so, re-install the graphics driver as soon as you get a working screen.
After that, or if you are getting no power to the board / power but no action from fans, suspect a component failure on the board. if the board checks out, check the CPU heatsink after 10 minutes of it being switched on, it should be warm, if it is not, the CPU may have failed
7/21/2011 8:52:03 AM • ASUS P5LD2... • Answered on Jul 21, 2011
I need all drivers for
Here is the link for Asus P5LD2 SE. Just click the download button below, select your operating system and all the drivers for Asus P5LD2 SE are there ready to download. Have a nice day.
4/15/2011 11:16:46 AM • ASUS P5LD2... • Answered on Apr 15, 2011
Where can i get for
These drivers should work for your board.
specify your operating system and download the drivers that you need.
http://usa.asus.com/product.aspx?P_ID=gD1ljCkUWy1Y3yMG&content=download
2/3/2011 3:05:57 PM • ASUS P5LD2... • Answered on Feb 03, 2011
Hi What maximum amount of HDD
HDD size is driven by the BIOS and Operating System you're running, not the motherboard itself.
2/3/2011 5:45:13 AM • ASUS P5LD2... • Answered on Feb 03, 2011
2answers
Driver
You can download driver software from here :
http://www.downloadatoz.com/driver/download/5458,asus-p5ld2-vm-motherboard-driver.html
http://www.driversbay.com/drivers/bios-motherboards/asus/p5ld2/microsoft-windows-xp/
Choose driver match with your motherboard specification.
Hope this help and if this helpful RATE please.
2/1/2011 2:05:49 PM • ASUS P5LD2... • Answered on Feb 01, 2011
0answers
ASUS P5LD2 Motherboard Logo
53 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Marvin
Marvin
Mehandi Husain ...
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
need all drivers
  • Computers & Internet
