20 Most Recent ASUS P5NT WS (P5NT WS GREEN) Motherboard Questions & Answers
2answers
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
11/28/2012 10:22:36 PM • ASUS P5NT WS... • Answered on Nov 28, 2012
I HAVE ASUS P5NT -WS MOTHERBORD ,WHAN I INSERT 2X2
the bus speed of both are not the same i.e. FSB(IN MHZ)
12/31/2010 12:33:02 PM • ASUS P5NT WS... • Answered on Dec 31, 2010
Hello. My Asus p5nt ws motherboard
hi remove ur proceesor and cpu fan clean the sudfwace of the fan and processor apply a hin coating of heat sink solvent and place back the processor in the socket and tightly place the processor bank int its place if still not working change the proceesor with your freind that fits the socket if still not working you have problem with MOSFET in your motherboard use a multimeter and check the MOSFET
11/2/2010 10:53:51 AM • ASUS P5NT WS... • Answered on Nov 02, 2010
I can not seem to get an image to display on my
What about CPU?
Is that BIOS version, that you have right now, supports your CPU for sure?
Did you try different(slower) CPU?
9/19/2010 10:19:29 PM • ASUS P5NT WS... • Answered on Sep 19, 2010
4answers
P5NT won't boot
Have you tried clearing the CMOS by removing the battery with PSU off and then shorting the 'reset cmos" (or similar) pins on mobo?
Also found this on the ASUS web site under the specs for the P5NT WS board...
01.gif ASUS CrashFree BIOS 2
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support DVD. Users can reboot their system through the support DVD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Have you tried this?
12/30/2009 9:38:20 PM • ASUS P5NT WS... • Answered on Dec 30, 2009
Got problems with lan drivers,Is it possible that
The drivers CD that came with the MoBo should contain all the necessary drivers.
It is possible that you have unkowingly skipped the LAN driver instal.
Put the CD in again and exit the setup, then go to My Computer and open the CD, find the LAN driver folder and install from there.
10/3/2009 8:47:40 PM • ASUS P5NT WS... • Answered on Oct 03, 2009
ASUS P5N T
First of all disconnect the Hard Disk do a check of switching on your comp and leaving it in on condition till you switch it off , repeat this exercise to ensure that there are no hardware problems . If your checks yield positive results then all you have to do is clean your hard disk thoroughly of any prevoius installations using the hard disk prep tools which you can download or obtain from vendor and then reinstall the OS .
5/13/2008 7:11:17 AM • ASUS P5NT WS... • Answered on May 13, 2008
My ASUS Monitor saying no signal. Was working fine yesterday and all cables are connected!
try restarting computer. If it does not correct problem, either monitor is bad or video card in computer is bad. Everything worked find before problems. Monitors are easily replaced.
12/7/2022 10:17:02 PM • ASUS Computers &... • Answered 2 hours ago
I need the setup disc for an ASUS V9950 Ultra Graphics Adapter
Hello the graphic card is maybe too old for win 7.But the vista driver works sometimes on windows 7Here is the 64 bit version: http://www.nvidia.com/object/winvista_x64_96.85_2.htmlAnd here the 32 bit:http://www.nvidia.com/object/winvista_x86_96.85_2.htmlHere is the main download page:http://www.nvidia.com/Download/index.aspx?lang=en-usRemember to select the driver for your system a 64 bit driver will not run on a 32 bit.If its not working with the drivers the graphic card must be renewedwith a card that supports windows 7. Good luck
10/31/2022 10:34:02 PM • ASUS Computers &... • Answered on Oct 31, 2022
5answers
An operating system wasn't found. Try disconnecting any drivers that don't contain an operating system. Press Ctrl+Alt+Del to restart and over and over what shall I do
You can go into the BIOS settings to see if the hard drive is shown there, if it is not then it is toast. You can also take it out and use another computer with a converter to test it for other issues. Or you can just replace the hard drive.
10/9/2022 4:52:13 PM • ASUS Computers &... • Answered on Oct 09, 2022
Asus A6R. I had to replace the battery because it emptied itself within 10 minutes.
wrong battery , sellers on ebay lie about them. many have no clue at all so only buy the battery stated in your users manual by technology type , and voltage, cell counts. (and phyical sizes and form factor) Asus A6R is a note book PC. the pack is custom sized (phy) snap in battery pack module. the tech is rechargeable lithium with 8 cells (series /parallel conn) 3.7v per cell. capacity 4400 mAh , 14.8V charged. like this. https://www.replacement-laptop-battery.com/asus-a6r-battery-14756.html learn not laptops charge. the charger is not in the power AC pack at all it is a chip on the mobo of the PC. main board. so there are 3 parts. 1: the DC /AC power park. warm never proves charging works. 2; the charge CHIP on mobo 3: and the batter, so never have just 1 battery so you know what is wrong, and AVOID NOS. AND THIS IS BOGUS 10.8V 4400 mAh ASUS.COM TELLS YOU THAT IS AND WAS WRONG. AND 10.8 Divided by 3.7 is 2.8 cells, how can that happen?, easy reading typo's online. and is bogus. sorry buy only new batteries.
9/14/2022 8:49:05 PM • ASUS Computers &... • Answered on Sep 14, 2022
Asus laptop/Rocketfish HDD problem transfering files? Windows 11 has modified the way some apps work
Posting follow-ups as a new post doesn't work here at Fixya because posts are not threaded by poster or subject. This post has absolutely no context to your previous question. The post here should have been posted as a reply to Larry Ng by clicking 'Comment' under his answer to you. FWIW, Larry is our Fixya computer guru and likely the only person on the planet that can fix problems like you have. He has knowledge like no other person I know! https://www.fixya.com/support/t29885843-using_asus_vivobook_win_11_want_send ..
8/18/2022 8:04:31 PM • ASUS Computers &... • Answered on Aug 18, 2022
Asus VH242 Monitor - the blue menu screen will pop open randomly and then scroll through all the options and I can not make it disappear again.
1. disassemble the monitor. 2. change the buttons for power and other function buttons. 3. always remember to replace with genuine parts.
8/13/2022 2:12:04 PM • ASUS Computers &... • Answered on Aug 13, 2022
Asus laptop x509ma won't turn on
Hi, It sounds like you've done the basic troubleshooting. Please call Asus to verify that you've not left any procedures out: 1 800-820-6655.And if this issue still persists, you can attempt to replace the laptop under your warranty. Thank you
7/28/2022 9:18:18 PM • ASUS Computers &... • Answered on Jul 28, 2022
Asus vh192d monitor power is auto off computer is running
that means the PC video out is dead. and all monitors show NO SIGNAL and go to sleep by law. TURN MONITOR ON LAST AND IT SHOWS NO SIGNAL, NO SYNC OR OUT OF RANGE ERROR BAD pc (none told)_ bad video card, bad cable or a dead PC. just because pC faNS SPIN DOES NOT MAKE IT GOOD.
7/16/2022 7:31:11 PM • ASUS Computers &... • Answered on Jul 16, 2022
I cant get gmail to give me a new password
ask them we are not them we can not ask for you. nor try to hack them. or just start over with new account, ask them is the answer. and told here like 10000 times contact them directly , as seen on their contract page online
6/9/2022 4:32:45 PM • ASUS Computers &... • Answered on Jun 09, 2022
How to reformat asus vivobook X202e WINDOWS 7?
so had w8 right and you meant down grade it to w7, from 8? if yes say so. the whole hdd will kill the os dead and gone 100% gone what to say is now to run recovery do you have the w7 install disk?s image recovery Restart your Notebook PC then press F9 per the manual if F9 is used, pC goes to w8 not w7 w8 sure does not have down grade option. w8 can be upgraded to w10 for free and is best. w7 is now an unsupported OS. w10 was offered too july 1015 for free then too. did you miss that great opportunity, or fear w10 ? w7 is not sold now over any counter w7 is not on the hdd image F9 only 8.1 is supported by oem make asus as seen here only 64bit 8.1 ( to get all drives and utilities) https://www.asus.com/US/supportonly/X202E/HelpDesk_Download/
6/9/2022 4:11:26 PM • ASUS Computers &... • Answered on Jun 09, 2022
Need asus rescue password for 2015/08/03
on what , not told WHAT, its computer related but WHAT fails?
6/9/2022 2:11:57 PM • ASUS Computers &... • Answered on Jun 09, 2022
Where do i find an operators manual for Asus c300
asus.com from 1995 to now, we love them. they are PRIME GRADE OEm as is DELL.
6/9/2022 2:11:03 PM • ASUS Computers &... • Answered on Jun 09, 2022
ASUS P5NT WS (P5NT WS GREEN) Motherboard Logo
8 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Marvin
Marvin
Mehandi Husain ...
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
  • Computers & Internet
