20 Most Recent Lenovo ThinkPad X60 Tablet PC Questions & Answers
What is my lenovo thinkpad serial number
go to Lenovo website auto detect and serial number will come up
6/16/2015 1:44:24 PM • Lenovo ThinkPad... • Answered on Jun 16, 2015
3answers
Lenovo x60 wireless problem
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  • Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
10/14/2014 6:05:22 AM • Lenovo ThinkPad... • Answered on Oct 14, 2014
Look up serial number
This is usually located on the underside of the tablet and is almost microscopic in size. Once you find and can actually read it be sure to write it down.
7/22/2014 4:16:07 AM • Lenovo ThinkPad... • Answered on Jul 22, 2014
I turn on my laptop ad what i get is a fan error
I turn on my laptop notebook lenovo s10-2 ad what i get is a fan error message after which it turns off but thiers still power what could be the issue and how to solve it. i can not use now my laptop
3/8/2014 5:05:06 PM • Lenovo ThinkPad... • Answered on Mar 08, 2014
0answers
Touch screen function not working but mouse working
try to shut it off. and turn it on after 10 sec. dont touch the screen when the unit is booting.
10/17/2012 2:23:47 AM • Lenovo ThinkPad... • Answered on Oct 17, 2012
2answers
Slow computer
The reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo PC. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.If you want to fix the problems more efficiently, try the Lenovo speed up program, available here: http://www.speeduplenovo.com/Cheers!
9/3/2012 1:55:41 PM • Lenovo ThinkPad... • Answered on Sep 03, 2012
3answers
Press the power button the
Have you tried pressing F1 while booting?
7/15/2011 2:14:22 AM • Lenovo ThinkPad... • Answered on Jul 15, 2011
I can't find the correct
Try one of these WEB sites, They detect the drivers your computer needs automatically and downloads and installs them.
Driver Detective
http://www.drivershq.com/
Driver Guide
http://driverguide.com
Driver Pro
http://driver-pro.com/related/english/device-driver-updates/?a=15810&gclid=CO6FoNDKtp4CFRhfagodEQhWlQ&hit=1&l=45 b>
5/4/2011 10:24:40 AM • Lenovo ThinkPad... • Answered on May 04, 2011
I cant play music or
double check if the volume is on mute there is a certain icon from your keyboard that indicate volume. try holding Fn key then press that volume button to unmute it. make sure also that ther eare no headphone connected as it will disable sound if you are expecting it from speakers. you may also try checking the driver status if you need to reinstall it or update it. simply go to control panel > system > hardware tab > device manager to check audio device there, if the icon has yellow marking on it then that is the problem you just need to reinstall or update the driver for audio by either using the driver disc that came with the system or downloading it from the manufaturers website
2/25/2011 2:30:10 PM • Lenovo ThinkPad... • Answered on Feb 25, 2011
I have been try to
Press the keys together on your keyboard. Ctrl, Alt, Delete Then enter your User name and Password when prompted.
8/12/2010 5:40:12 PM • Lenovo ThinkPad... • Answered on Aug 12, 2010
My lapttop is stuck on the login window and I can
Removie battery and remove all the screws on the bottom by the Hard drive or dvd drive. You will see a white and red cable, depending on the year a green cable. Follow cable and disconnect it. It should disconnect the Bios and reset it. connect after 3 to 5 minutes
6/13/2010 11:01:32 PM • Lenovo ThinkPad... • Answered on Jun 13, 2010
My lenovo thinkpad x60 tablet pc was locked, and i
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Otherwise you can check out theses 2 tutorials, with few skill you can make it yourself: -http://www.allservice.ro/forum/viewtopic.php?t=47&start=0 -http://marc.info/?l=full-disclosure&m=111234041830357&w=2 Unfortunalty, no other ways other round. Thanks and have a nice day J-
6/9/2010 7:50:33 AM • Lenovo ThinkPad... • Answered on Jun 09, 2010
Lost manual need copy
5/6/2010 9:14:11 AM • Lenovo ThinkPad... • Answered on May 06, 2010
Freezing laptop
It is possible that the driver is not installed correctly, or not even installed at all. What you can try, is to go to manufacturers web site, and download the driver needed for it, and install it
3/2/2010 12:01:58 AM • Lenovo ThinkPad... • Answered on Mar 02, 2010
3answers
Deleted a disk drive partition
You can still view the D partition. Right MY COMPUTER - select MANAGE - on the left hand side select DISK MANAGEMENT.
After selecting, on the right hand side you see the DISK 0 is your primary hard disk.
it is still divided into two. one is allocated which is C (in blue) and unallocated is D (in black)
to merge the partition you can use partition magic.
2/14/2010 12:09:03 PM • Lenovo ThinkPad... • Answered on Feb 14, 2010
Lenovo ThinkPad X60 Tablet PC Logo
Popular Tags
56 questions posted
Top Lenovo Tablets & eReaders Experts
Ekse
NOEL
NOEL
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
slow computer
  • Tablets & eReaders
