The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
A print quality defect in which pages contain random spots or splotches (click on the link to see sample http://bit.ly/mRX3qz) may occur after the replacement of a supply item or the clearing of a paper jam. If your printed output resembles the example shown, please do the following:
Print the Menu Settings page to check the levels of your consumable supplies (i.e. items such as toner cartridges and photoconductor units). Supplies that are at or near the end of their functional lives can cause various print quality issues independently of the operation of the printer.
If any of your other supplies are low, replace them to see if this resolves the issue. Instructions for replacing supplies can be found in the User's Guide.
It is always advisable to print the Print Quality Pages to get a detailed look at your printer's output. These pages allow each color plane to be viewed independently to determine if the issue is with one color (possibly due to a single supply item), or with all the colors (indicating a more general issue with the printer).
If the above checks show that everything is normal, the print quality issue is probably a temporary situation which sometimes follows supply replacement or paper jam removal. Printing 5-10 additional pages should allow the issue to clear up on its own.
If the print quality issue does not clear on its own, please contact Lexmark Technical Support
Click the link http://bit.ly/nSKQ65 for quality print information. The list will show print samples and provided a link right below the image. The link will give instructions on how to go about the procedure.
For further assistance, please call Lexmark Technical Support.
57 questions posted
232 Questions
138 Questions
65 Questions
57 Questions
64 Questions
