20 Most Recent
Zebra MZ 320 Thermal Printer Questions & Answers
El led del papel se queda parpadeando y no imprime
Units built before June 18, 2008
Units with a S/N having a Year Built and Week Built code earlier than "08-25" are reset using the following procedure:
1. Open the media compartment and remove any media.
2.
Press the Feed button and hold it approximately ten seconds until the
Power, Communications and Error indicators turn off and stay off.
3. After the three indicators turn off, reload the media and close the media compartment cover.
4. Wait at least ten more seconds and press the Power button. The Printer will restart and normal operation can resume.
Units built after June 18, 2008
Units with a S/N having a Year Built and Week Built code of "08-25" or later are reset using the following procedure:
1. Press and hold the power button for 5 seconds and then release. The printer will power down.
2. Re-start the Printer as usual. Any pending data in the printer will have been deleted and must be re-sent.
My zebra mz320 ask for key when I try connecting
Bluetooth often requests a KEY - 4 digit - when it establishes connection - often it will ask you to enter the KEY on one device and then you have to enter the KEY on the connecting device
However, devices such as Cars etc - may have a default key - usually
0000 or I have also used
1234, but
0000 is the most common I have used.
- If this solutions solves you problem, please do not forget to rate my solution.
- If not, then please comment back so I can help some more
