20 Most Recent
Compaq TC1000887 TC1000 Tablet PC Questions & Answers
Outlook 2003 and Outlook 2007
When sending emails, while on the move (i.e using different wireless or broadband connections), if you do not click authentication required for the outgoing server and enter the username and password, or click use the same as incoming server the emails will not successfully deliver. It all depends on which email provider you are using.
I want to start inter net from my laptop what to
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Laptop wont charge
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
Disassembling PDA's
I have solved my problem vith PDA's already. Simply. I opened housing of PDA's and checked connect to screen. Thank you for intrest about to solve my problem. Hi Zdenek.
How do I hook an external Monitor to my HP Compaq
You will need to go into....
CONTROL PANEL >> Display >> SETTINGS tab.
There you will see a pull down menu to select 1 of 2 monitors.
You have to choose to have them both on all the time (multiple monitors)
Use IDENTIFY to bring up the display # onscreen.
Please accept this answer to remove it from the work queue.
:D
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
