20 Most Recent Lexmark E120 Laser Printer Questions & Answers
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Lexmark E120... | Answered on May 13, 2013
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Get the Printer Replaced!!!!!
Good Luck!!!!!
Lexmark E120... | Answered on Feb 27, 2013
You may download the user guide and more from here.
Lexmark E120... | Answered on Jan 31, 2013
Please make sure that the printer is plugged directly to the wall outlet. The printer should not be connected to any Automatic Voltage Regulator (AVR) or any Uninterrupted Power Supply (UPS). If it is, please connect it directly to the wall outlet.
Lexmark E120... | Answered on Aug 27, 2012
This problem may be caused by the printers' system board. I suggest you contact Lexmark Technical Support.
Lexmark E120... | Answered on Aug 23, 2011
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Lexmark E120... | Answered on Aug 01, 2011
You may be able to get a printer driver for this printer from the Lexmark WEB site.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark E120 Laser Printer is compatible with Windows 7 and no additional drivers are required for both 32-bit and 64-bit versions. It installs automatically without extra software. Click here for Lexmark E120 Windows 7 compatibility details.
Hope it Helps!
CreativeTECH
Lexmark E120... | Answered on Jul 22, 2011
Please click on the link http://bit.ly/rkP361 to see instructions on howto go about the procedure. For additional assistance,please contact Lexmark Technical Support.
The printer operator panel has two buttons and sixlights (the Continue button is both a light and button). Lights indicate the status of the printer. Buttons are usedto continue or cancel the current print job. The lights are represented byReady/Data light, Toner Low/Replace PC Kit light, Load/Remove Paper light,Paper Jam light and Error light. Since you've mentioned that printer has 4 red lights,we would like to know which light is it. Please provide us more information. For further assistance, please contact LexmarkTechnical Support.
Lexmark E120 Laser Printer Logo
73 questions posted
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
keeps printing test page
  • Office Equipment & Supplies
